The great unknown- Clutches
Re: The great unknown- Clutches
Postby ellis93 » Sun Feb 17, 2013 3:16 pm
txs wrote:Caleb, if you dont have bad hot spots or heat cracks or much scoring, i use a DA with 80 grit on flywheels, this has always worked well for me.
Glad to see someone else does things simple like me
Postby cmann250 » Sun Feb 17, 2013 3:29 pm
I'm all for not wasting money. Don't the little grooves in the flywheel just amount to more surface area after the clutch is broken in and therefore a better bite? :lol:
Postby dazedandconfused » Sun Feb 17, 2013 3:30 pm
I do the same if they aren't bad. He just mentioned it slips when we were talking about it up there. That just makes me wonder if its hot spotted.
Postby cmann250 » Sun Feb 17, 2013 3:43 pm
I'll know this week. I've never smelled it burning
Postby PToombs » Sun Feb 17, 2013 5:19 pm
Caleb, on my 47RE I pull the crossmember and bolt the trans mount to the rear of the jacks plate, then use a wood block to take up the space between the trans pan and the jacks plate in the front. It balances just about perfect there. Not sure how close it will be on your ZF, but it's a starting point.
Postby ellis93 » Sun Feb 17, 2013 5:42 pm
Alright cat daddy,this might be different than what you'll use but my trans Jack has about a 1sqft platform to contact the bottom of a trans. No really a good thing on a trans with a rounded bottom. What I use to combat that is a 2x12 with a 3/4" piece of plywood screwed to the front with a V cut in it for the bottom of the trans to sit on. When I use this holding apparatus I also use a 1" wide ratchet strap to hold it to my trans Jack.
On that zf,once the cross member is out of the way,cut yourself a board about 10 or 11" in length, build and attach a piece that has the V cut in it to the 11" board. Now position the rear of your board on the contact surface of the trans mount,butt it up against the mounts studs. Position your floor Jack under the board,I assume that's what you'll use,and strap it together.....good to go ;)
Postby cmann250 » Sun Feb 17, 2013 5:54 pm
Make a cradle out of wood? I figured I'd make a custom wooden trans jack attachment for my floor jack. So essentially the same thing.
Was that some jargon of young folks that you adressed me with?
Postby Tacoclaw » Sun Feb 17, 2013 5:55 pm
Young folks back in the '60s maybe. :lol:
Postby ellis93 » Sun Feb 17, 2013 6:01 pm
cmann250 wrote:Make a cradle out of wood? I figured I'd make a custom wooden trans jack attachment for my floor jack. So essentially the same thing.
Would you rather me call you sugar britches :lol:
Postby cmann250 » Sun Feb 17, 2013 6:06 pm
ellis93 wrote:Would you rather me call you sugar britches :lol:
I believe the "Cat Daddy" is a dance that urban folks do. Sugar britches is just a bit too far :lol:
Postby dazedandconfused » Sun Feb 17, 2013 6:08 pm
Only if you whisper it into his ear. :lol:
Postby ellis93 » Sun Feb 17, 2013 6:21 pm
Well..... :lol:
Tiger Lilly work for you then?
Postby oldestof11 » Sun Feb 17, 2013 6:23 pm
dazedandconfused wrote:Only if you whisper it into his ear. :lol:
Right before you yell surprise. :lol:
Postby dazedandconfused » Sun Feb 17, 2013 6:26 pm
ellis93 wrote:Well..... :lol:
I prefer sweet cheeks. ;)
Postby cmann250 » Sun Feb 17, 2013 6:29 pm
Thank you for the invitation, but I'll opt out of the Trifecta of Queerness :puker:
