HP, TQ, Fuel Consumption
Postby oldestof11 » Sun Feb 17, 2013 12:04 pm
Found this today while doing some VE and VP37 (TDI) research.
180hp/440 tq (converted)
200hp/500tq
Notice the fuel consumption where it peaks in torque. Both of these were done with the VE. The 200hp/500tq graph uses LESS fuel per kW (HP) at a higher RPM than the 180/440...
Re: HP, TQ, Fuel Consumption
Postby Sutter1stgen » Sun Feb 17, 2013 2:48 pm
That's some cool info right there. Im glad I got o/d with 3.07 now. I've noticed even with the 6x16s that o/d, and the lower rpm I cruise at, has helped with fuel economy.
Eric
Sutter1stgen
Postby RCCUMMINS89 » Mon Feb 18, 2013 8:32 pm
Makes sense why my truck gets better fuel economy at higher rpms than my dad's.
Postby oldestof11 » Tue Feb 19, 2013 4:00 pm
Which is why my 4x4 4.10 equipped trucks got better mileage than "is possible".
Postby Mark Nixon » Tue Mar 26, 2013 9:09 am
Slowing engine speed doesn't necessarily help mileage.
'Working" an engine (low RPMs, high loads) will also increase fuel demand.
This is why more transmission gears, with a taller rear gear ratio, tends to work out over fewer transmission gears with the same ratio.
You're keeping the RPM where it needs to be, for the best efficiency, with more gears.
Deeper gears "control" the engine's power range.
I will say that I have gotten my best mileage, which was with 4.10s in a moderately loaded truck, keeping it under 65mph.
That was 28mpg on a 1991.5 with a 5 speed and 2k weight in the bed, on a milder June day in the summer of '04.
BEFORE ULSD.
Postby 1STGENFARMBOY » Tue Mar 26, 2013 2:23 pm
I also got the best MPG with a 5spd / 4:10's in a flatbed cab-chassy 95 1ton.
Return to Competition
Users browsing this forum: No registered users and 106 guests
