BTW several hours ago I used this truck to tow my other 1st gen home after it lost a wheel and axle shaft in the rear axle towing the buggy home. This is two strandeds with two different 1st gen Dodges in one day!
dunes450r wrote:IIRC true runaway can't be solved with turning off the key, or even the manual shutoff lever, hence why people remove the intake and are ready to choke the turbo off
BC847 wrote:Not a stuck injector.
Read this, and see if you fall into it . . . http://dodgeram.info/tsb/recalls/605.htm
BC847 wrote:Splitting hairs with an axe, this may be a situation of uncontrolled full throttle, and not true "runaway".
As such, the FSS would stop the fuel supply to the H/R.
