Rattle plate fix
Rattle plate fix
Postby mhuppertz » Wed Mar 06, 2013 6:15 pm
I noticed that if I put my hand on the valve cover plate the engine was significantly quieter, so I traced the plate on some sound deadener and cut it out, then glued it to the backside as pictured. It made a difference.
mhuppertz
Re: Rattle plate fix
Postby PToombs » Wed Mar 06, 2013 6:31 pm
It was probably rattling because the rubbers were beat. A washer under each end may have done the same thing. ;)
Postby mhuppertz » Wed Mar 06, 2013 6:53 pm
PToombs wrote:It was probably rattling because the rubbers were beat. A washer under each end may have done the same thing. ;)
It actually wasn't rattling, but it was transmitting noise.
mhuppertz
Postby BC847 » Wed Mar 06, 2013 7:23 pm
Seems I tried the washer thing and the vibration had the washers cut into the plate. Rubber washers between the steel washers and plate are a must I think.
Your insulation trick is still neat. 8)
Postby RumbleFish » Wed Mar 06, 2013 7:26 pm
Tell us about the dart!
Postby mhuppertz » Wed Mar 06, 2013 8:09 pm
RumbleFish wrote:Tell us about the dart!
Good eye!
1969 Dart GT, 273 V8, automatic. It was bought off the lot brand new in 1969 as a graduation present for my friend. She drove it in So-Cal for twenty years, then parked it. When I pulled it out of her yard it had no moved since 1989. It has zero rust except on the surface of the roof, hood and trunk.
I had it running but the next time I started it the valves all stuck and some bent.
That's ok, because I am yanking it to make room for the 440 I am building in my garage!
Still looking for an A833 4 speed.
mhuppertz
Postby Mark Nixon » Wed Mar 06, 2013 8:53 pm
mhuppertz wrote:Still looking for an A833 4 speed.
Told you where you could go for that.
I'm not playing in that rat race anymore, this 1stgen stuff is almost more than I want to take, as it is sometimes. :roll:
Nice fix on the sound telescope. :D
Postby mhuppertz » Wed Mar 06, 2013 10:10 pm
I lost the guy's number. Would you mind sending it to me again?
mhuppertz
Postby apexfd » Sat Jun 01, 2013 9:21 pm
Good idea!
apexfd
