clutch time
Re: clutch time
Postby PToombs » Thu Mar 07, 2013 6:02 pm
Bryan, Ellis has a 2wd so that won't help him any! :P
Re: clutch time
Postby ellis93 » Fri Mar 08, 2013 8:13 am
Well I found another option....but they aren't rated.
anyone heard of them
http://www.specclutchsuperstore.com/ful ... 19967.html
Re: clutch time
Postby RCCUMMINS89 » Fri Mar 08, 2013 9:01 am
I've never heard of them.... it sounds promising, but never know.
Re: clutch time
Postby dazedandconfused » Fri Mar 08, 2013 9:03 am
There was a couple threads a few years ago on other forums about them. They weren't holding anymore power then stock clutches.
Re: clutch time
Postby dunes450r » Fri Mar 08, 2013 9:27 am
i'm not one to try and test unproven stuff......just get a one of the 13" valair or SB's and go for it.
dunes450r
Re: clutch time
Postby RCCUMMINS89 » Fri Mar 08, 2013 9:30 am
If he's anything like me he is trying to find something that doesn't have a couple hundred dollar name price add on.
Personally I like Valair over Southbend though..... I feel it is a better deal.
Re: clutch time
Postby ellis93 » Fri Mar 08, 2013 9:47 am
RCCUMMINS89 wrote:If he's anything like me he is trying to find something that doesn't have a couple hundred dollar name.
^^^ this
I'm trying get ol'kennys clutch to call me back again to talk about building me a custom clutch. Hell I figure if I'm gonna have to cough up a G for a freakin clutch it might as well be dang close to what I want.....which is 13" with a 3" wide contact surface like the Sachs only with more clamping psi. That's what I figure is the money shot,surface area +clamping psi+single disc= happy Ellis.
Sadly if the dude doesn't call back or can't/won't....I guess I'll buy from the others:(
Re: clutch time
dazedandconfused wrote:There was a couple threads a few years ago on other forums about them. They weren't holding anymore power then stock clutches.
Bummers
Re: clutch time
Postby RCCUMMINS89 » Fri Mar 08, 2013 9:49 am
13" with a 3" clamping surface can be had for under a g
South Bend - 425/900 organic 13" w/flywheel 3" clutch facings - $825.00
Re: clutch time
Postby oldestof11 » Fri Mar 08, 2013 6:22 pm
^^^ this
Yeah, the Sachs rating for clamping is somewhere around 2800lbs. Aftermarket clutches start around 3200lbs. I want to try a 4500lbs clamp load on this clutch. I think it will hold nearly 500hp.
Re: clutch time
Postby PToombs » Fri Mar 08, 2013 6:59 pm
I've met you, and you don't have enough leg for 4200lbs clamping force! ;) :lol:
Re: clutch time
Postby oldestof11 » Sat Mar 09, 2013 10:56 am
It isn't how long you're leg is, it's how you use it.;)
FWIW, I can push 275lbs on the leg machine at my employers workout room.
Re: clutch time
Postby cmann250 » Sat Mar 09, 2013 11:02 am
Can't be worse that the old TD24s that the logging companies used. Them boys had some leg strength.
Re: clutch time
Postby ellis93 » Wed Mar 13, 2013 1:59 pm
Well.....
It's here 8)
Re: clutch time
Postby dazedandconfused » Wed Mar 13, 2013 2:01 pm
Who's clutch?
Return to Transmission
