Postby CumminsPower59 » Fri Apr 12, 2013 2:58 pm
Well, the biggest fasteners we got around here at work are 1". Gonna have to go to Fastenal or something...
Postby PToombs » Fri Apr 12, 2013 3:36 pm
I patched mine too. I replaced 1 or 2 and put in a piece of plate on another one. I cut the hole with a torch, nobodies going to see it and the cab found the center all by itself! :mrgreen:
Postby redneckroot » Fri Apr 12, 2013 10:05 pm
Seeing these pictures reminds me of when I restored mine. Good luck and keep up the good work.
redneckroot
Postby CumminsPower59 » Fri Apr 12, 2013 10:23 pm
Thanks Tom. Didn't you use a 2wd auto cab on yours? If so, do you have any pics on how you did the floor modifications? Just gettin ideas...
Postby Philip » Sat Apr 13, 2013 4:46 am
Pete used a 2WD cab on his truck. If I remember right he has some pic's of the floor board work.
Postby 1STGENFARMBOY » Sat Apr 13, 2013 6:17 am
Ike i mite be interested in the deep aluminum pan on that 727.
Postby CumminsPower59 » Sat Apr 13, 2013 9:16 am
Dar, it is a nice B&M unit, I will be sure to pull it when it goes to scrap, as 727's aren't even bringing $250 around here...
Postby 1STGENFARMBOY » Sat Apr 13, 2013 12:49 pm
Thank you kind sir, ......see i knew you were nicer than all these guys said. :lol:
Postby CumminsPower59 » Sat Apr 13, 2013 1:12 pm
You're welcome!
Shouldn't be listening to what these clowns say anyways :lol:
Postby PToombs » Sat Apr 13, 2013 4:18 pm
Screw both you guys! :P
Postby CumminsPower59 » Sat Apr 13, 2013 5:56 pm
Sorry Pete, but I am not into gingers ;)
Got 150lbs of black blasting media today, along with a box of cut off wheels for the grinder, and the weather is supposed to be dry for the next few days. Hope to blast the underside of the cab tomorrow, and get a coat of primer on it...
Postby redneckroot » Sat Apr 13, 2013 8:04 pm
Yeah I used a 2wd cab.
Before I cut it.
After I cut it.
Difference between the two.
All back together.
redneckroot
Postby CumminsPower59 » Sat Apr 13, 2013 8:09 pm
Tom, you are the man!!! Thanks a bunch!!!
Postby Mark Nixon » Sat Apr 13, 2013 8:22 pm
Ike, as we were talking earlier to-day, I'll have all the parts you need ready by next Friday and we can either meet up, or I'll run them over to Wilton.
I just got in from Tennessee, been a long, trying week and I actually cut the trip short because I was tired of trying to get somewhere and either the weather not cooperating, or people not answering their phones.:roll:
I started out just fine, then the storms went through Arkansas, which basically killed Tuesday and most of Wednesday, but I finally got the POS home.
Turns out the rockers have some rust, then it has a couple dents, but it's a very nice body overall.
Postby CumminsPower59 » Sat Apr 13, 2013 8:38 pm
Well, hate for you to make two trips, so if you can make it over on Friday, that would be freakin' awesome! I just looked at the forecast, it just went to sh!t for the next few days, doesn't look like I can get much done outside, I guess I will have to put a bunch of junk outside under tarps so I can move that cab inside to prep it...
Users browsing this forum: No registered users and 125 guests
