24 valve help
All of 'em
24 valve help
Postby skilletky » Thu Apr 18, 2013 10:37 pm
So I got me a 24 valve now, thanks Andy. I love that truck. I am not going to go crazy with it as far as power, but I want to bump it up some. I am going to put an intake, exhaust , small programmer , and maybe a small set of injectors. My question is, what is the best performing brand to use and what should I stay away from? It's an 01 5 speed 2wd. Any help would be greatly appreciated.
skilletky
Re: 24 valve help
Postby burnt_servo » Fri Apr 19, 2013 6:03 am
a intake is a waste of money .
a 4 inch exhaust , block the waste gate so it makes around 30 psi of boost and a set of 275 hp injectors .
for a programer i would seriously look at the ones blue chip offers .
you are also going to need a fuel pressure gauge and a aftermarket fuel pump ( i've been running a fas for the last 3 years without issues )
your also going to want to add a boost gauge and pyro gauge
'93 w250 .... stock ...
burnt_servo
Re: 24 valve help
Postby ellis93 » Fri Apr 19, 2013 6:19 am
LIFT PUMP! number one most important,can't express it enough......hell,it might be more important than a egt gauge :lol:
I like the airdodge stuff
I've ran the diabolo sport power puck,it gave me 2mpgs more and some power. Its kinda tame.
Still have it too! Wink wink ;)
Re: 24 valve help
Postby skilletky » Fri Apr 19, 2013 6:52 am
definatly gonna get a fuel pump. ellis, how much? gonna pull the gauges from the 1stgen and put in this one. thanks for the info on the intake. so all i need to get is a lift pump, bigger exhaust, and ellis' power puck ;)
skilletky
Re: 24 valve help
Postby ellis93 » Fri Apr 19, 2013 7:07 am
I'll scratch up out of my tool box and pm you a pic....then you can "make offer" ;)
Now days they're like 179new so it's not worth "alot"
Re: 24 valve help
Postby skilletky » Fri Apr 19, 2013 7:32 am
sounds good. just talked to one of my drivers, and he has 2 new bhaf and is gonna give me one for free, which is pretty tits.
skilletky
Re: 24 valve help
Postby dazedandconfused » Fri Apr 19, 2013 8:51 am
Glad you like it Chris. Check out TS performance for a nice box if you don't run the puck. That and a new set of RV275s should be around 350 to the wheels. I had 5 guys call me today on it after going 2 months with no calls.
Re: 24 valve help
Postby skilletky » Fri Apr 19, 2013 9:09 am
dazedandconfused wrote:Glad you like it Chris. Check out TS performance for a nice box if you don't run the puck. That and a new set of RV275s should be around 350 to the wheels. I had 5 guys call me today on it after going 2 months with no calls.
it always works that way, lol. thanks for the info. will a stock clutch hold that?
skilletky
Re: 24 valve help
Postby dazedandconfused » Fri Apr 19, 2013 9:11 am
Depends how you drive it. That isn't the stock clutch in that truck but I can't tell you if it was a stock replacement or something different. There was a paper in the glovebox showing clutch and trans were rebuilt at 198,000.
Re: 24 valve help
Postby skilletky » Fri Apr 19, 2013 9:55 am
i dont plan to beat on it much at all, just a little go go. i wonder if they addressed the 5th gear nut issue. that been rattleing around in my head too
skilletky
Re: 24 valve help
Postby PToombs » Fri Apr 19, 2013 4:24 pm
skilletky wrote:i dont plan to beat on it much at all
:jumpsmile: Yeah, right! Remember who you're talking to here? ;) :lol:
Re: 24 valve help
Postby skilletky » Fri Apr 19, 2013 7:09 pm
Everyone keeps telling me that.
skilletky
Re: 24 valve help
Postby skilletky » Mon Apr 22, 2013 1:33 am
so im thinking once i get a lift pump, i am gonna get either a edge comp box, edge juice w/ attitude, or a ts mvp box. ive talked to some people who have owned or own a 24 valve, and they all like the comp box. gonna try and dig up more info or reviews on it.
skilletky
Re: 24 valve help
Postby PToombs » Mon Apr 22, 2013 5:19 pm
Didn't Edge close its doors? I remember some outfit that makes programmers closed when the EPA went after them because they couldn't meet emission specs. If you can buy a new box that would be ok, but I'd be leery of buying a used box and having the company gone when you need updates or something.
Re: 24 valve help
Postby dazedandconfused » Mon Apr 22, 2013 5:36 pm
Quadzilla closed its doors. Chris my other 01 ran just a comp and made 305hp with just that. My bote would go drag comp for the further fueling and stay away from the juice.
Return to Other diesels
