Hey...it's a start
Re: Hey...it's a start
Postby Sutter1stgen » Sun May 05, 2013 3:47 am
That thing looks bad a$$!!! Makes me want to build one even more.
Eric
Sutter1stgen
Postby lopez dodge » Mon May 06, 2013 7:41 am
thats my new background . that is sweet
1991.5 ..getrag super40. 40,horse injectors,4"to 6" exhaust , bhaf 2nd gen intake,custom pin timed to the head ..1/4 14.9@93mph 5,500' with a little propane
lopez dodge
Postby turboram » Mon May 06, 2013 7:44 pm
Cool !!!!!!
turboram
Postby Deathrod » Sat May 11, 2013 2:18 pm
Made it to my works annual car show today. So far so good, had to fab up an extra support for lower tubro, it vibrated to much for my taste
Deathrod
Postby RCCUMMINS89 » Sat May 11, 2013 2:26 pm
How much boost are you making with those factory sticks? and egts?
Postby PToombs » Sat May 11, 2013 5:53 pm
How is your top held on? I never saw a good shot of it off in the other pics.
Postby Deathrod » Sun May 12, 2013 8:52 pm
Boost I've only seen about 45 psi, which is about the same as before but it's making a lot more power, it does need the bigger sticks to spool them harder. Egts are around 1000 in like a 0-80 run......not bad for no ic.
Roof sits in a channel and just has 4 latches that catch under the channel. When I get fuel it's easier to pop the top off and climb in to fill the tanks. I did that one day then hopped on the freeway.....got up to about 70 mph and whoosh, before I knew what was happening the roof flew off, almost said screw it and kept driving, it's gotta be trash. But I pulled over picked it up, not hardly a smudge on the thing!!!, it's built like an interior door, probably weighs 10 lbs or less.....guess it just floated down. Now I always make sure I latch it down :oops:
Deathrod
Postby jkidd » Thu May 16, 2013 10:24 am
Nice work!
jkidd
Postby PToombs » Thu May 16, 2013 6:09 pm
What air filter are you running? I was just looking for one for mine and can't find siht. I'm limited on space, unlike you! :lol: Yours looks like it may fit, how long is it? I don't want an oiled filter, prefer a dry type.
Postby Deathrod » Fri May 17, 2013 1:07 pm
PToombs wrote:What air filter are you running? I was just looking for one for mine and can't find siht. I'm limited on space, unlike you! :lol: Yours looks like it may fit, how long is it? I don't want an oiled filter, prefer a dry type.
It's an AFE filter, I just happened to have 2 for my powerstroke, when I got the turbo I slid it on and was like holy sh@t something easy and I didn't have to buy one. They do make the same one dry for the filter set up, I looked in to it a while back but the trucks turbo isn't dusted at all after about 5 years. It's 8" long.
Deathrod
Postby Deathrod » Fri May 17, 2013 1:14 pm
New injectors vs old. And my lug nut welded to a slide hammer worked awesome yanking the old ones out, they have never been out in 22 years.
Also had to extend my exhaust a few inches (tryin to hold off cancer) and had enough header wrap to cover the weld.
Had to tune it a bit in the garage, but got hungry so that's where it sits, gonna drive and tune it more after lunch
Deathrod
Postby RCCUMMINS89 » Fri May 17, 2013 8:28 pm
Did you drive it?
Postby Deathrod » Fri May 17, 2013 10:29 pm
Yup pegged my 60 psi boost gauge....whoops, probably not great on the stock valve springs. With stock injectors it would only push 40-45ish, so it's got more go. Didn't get a chance to watch the pyro...wot usually requires a passenger to watch, it's pretty violent and quick. I really think it needs higher gearing.....but ill deal with what I got.
On a side note with all this talk about thinner washers for the injectors, I noticed the 7-9mm adapters are the same thickness as the stock washers. Anybody make thin adapters?........hungry diesel....could be the first??? Corner the market on the 8 of us non ic guys!
Deathrod
Postby RCCUMMINS89 » Fri May 17, 2013 10:39 pm
How is the idle haze with them?
Postby Deathrod » Fri May 17, 2013 10:46 pm
Umm I think a little when it was cold but went away, I did give it some more timing after I drove it so that could change things.
Deathrod
