Postby CumminsPower59 » Mon Jun 10, 2013 9:15 am
All I did on the timing end was bump it 1/8" when I put the pump on. Some times it takes it a few cranks to light off, with the throttle down a bit...
Postby CumminsPower59 » Mon Jun 10, 2013 10:26 am
I put some clear tubing on between the fuel strainer and the lift pump, no bubbles or anything. Replaced the fuel filter with a new FS1221. Still runs like poo. I guess I am going to tear into the pump again and see what's what. Good thing I got three re-seal kits...
Postby CumminsPower59 » Thu Jun 13, 2013 12:02 pm
Well, problem solved. Solution? My own stupidity :oops: Upon re-assembly (1st time) I put the KSB piston in sideways, and both shims on the bottom of the spring. Proper re-assembly=great running pump.
Postby CumminsPower59 » Tue Jun 18, 2013 8:29 pm
Progress? Pictures? Yes and Yes!
Well, it runs, drives, steers and stops. Still got a lot of small stuff to finish, needs a stronger clutch as it pushes right through the one that's in it now, need to get the rear Kelderman single bag on, get the interior put together and speakers put in. Took it to town today, idle screw lock nut backed off and the screw went waaaaay in, good thing I had a handful of tools and some wire, got it turned to where the thing would idle decent and wired it in place to get back home. Got a weird fueling issue, when I let out of the throttle, it will chug down so low it almost dies, then pops right back up to proper idle speed. The more I turn the fuel screw in, the worse it gets, so bad that when I snap the throttle open, it'll chug down and die. Any suggestions?
Last edited by CumminsPower59 on Tue Sep 09, 2014 10:43 am, edited 1 time in total.
Postby Mark Nixon » Tue Jun 18, 2013 8:42 pm
CumminsPower59 wrote:...Any suggestions?
Yes!
Mow your grass and pick up your parts! :lol:
Anyone who's been here won't recognize the place now. :roll:
Glad to see you're making progress after your "logo addition".
Postby PToombs » Wed Jun 19, 2013 5:31 pm
I think you missed a step! The trans is sitting on the lawn! :lol: Looks good Ike, now to drive the siht out of it! ;)
Postby CumminsPower59 » Wed Jun 19, 2013 8:28 pm
I took it to work, got a few more bugs worked out of it, got a few complements too. I don't know how long I can run it, trying to be easy on it, really need to get a clutch ordered for it...any suggestions?
Postby bmoeller » Wed Jun 19, 2013 9:00 pm
South Bend all the way! :D
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby RCCUMMINS89 » Wed Jun 19, 2013 10:14 pm
Southbend is the best driving.
Valair is very good also.
Ask Ellis if he likes his Southbend, that IMO is probably the best upgraded clutch. PM me if you're interested in pricing.
Postby ellis93 » Thu Jun 20, 2013 3:30 am
Ike I like mine,decent pedal pressure no hurkey jurkey in reverse at low rpm. Well spent money imho ;)
Postby Bookshelf » Thu Jun 20, 2013 4:10 pm
ellis93 wrote:Ike I like mine,decent pedal pressure no hurkey jurkey in reverse at low rpm. Well spent money imho ;)
Which South Bend model do you have?
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby RCCUMMINS89 » Thu Jun 20, 2013 4:34 pm
South Bend 13125-OK-HD
Postby ellis93 » Thu Jun 20, 2013 4:36 pm
What Eric said
He'd know cause I bought it from him
Postby PToombs » Thu Jun 20, 2013 4:44 pm
I have a Valair, and it's jerky. It's also a 650 hp ceramic clutch so that could be why..... ;) It feels smooth on the pedal, but it's either in or out. It's a little too much clutch for what I'm doing with it, but I don't care! :lol:
Postby RCCUMMINS89 » Thu Jun 20, 2013 4:48 pm
You and me both Pete.............I have the Comp dual disc and it sucks.
