For the sake of argument...Gearing.
Postby Mark Nixon » Mon Jun 24, 2013 7:37 pm
What gear would one run an NV5600 6 speed with an NP205 in 4 low, hooked to a sled?
Is there any combo that would allow a taller gear, say 3.07s, with a 235-85-16 tire?
Would an NP241 be preferable to a 205 for the different gear ratio?
Don't read anything into this, these are only questions. :D
Re: For the sake of argument...Gearing.
Postby SuperiorRam » Mon Jun 24, 2013 7:59 pm
Edit
92 Cummins: DD, basic mods, topper, 9'2" bossV
92 Cummins: 10' tall, Rockwells and r1's "Dirty Addiction",
83 RC/SB Cummins: engine set back 18", block 89w/h20 after cooler, fire ringed and worked head, studs, billet 64/68/14w/race cover, custom header, bigger sticks, 47rh, dana 60, four wheel disk, and big Mickey Thompsons w/ Weld drag lites. "The Mustard Bucket"
SuperiorRam
Postby SuperiorRam » Mon Jun 24, 2013 8:02 pm
I think the 307's would be sweet with the 5600!!!! Hooked to a sled id do the 273 in low second gear with My ol common rail was 793/1865 and third gear was sweet I'd say second with any less power would be fine
SuperiorRam
Postby oldestof11 » Tue Jun 25, 2013 4:10 am
4low 2nd.
Postby Mark Nixon » Tue Jun 25, 2013 7:32 am
WHICH t-case, guys?
I realize that the NP241 has a lower 4 low ratio.
Postby rockbuggy4x4 » Wed Jun 26, 2013 10:58 am
What are the ratios on the 205 and 241?
Jimmy
--> '85 cab w/ '89 engine and trans stock with minor pump tweaks and a flatbed. **soon to get lots of goodies**
--> '95 jimmy not so stock
rockbuggy4x4
Postby CumminsPower59 » Wed Jun 26, 2013 11:31 am
NP205 is 1.96:1
NP241 is 2.72:1
Postby Hansen01 » Mon Jul 01, 2013 8:33 pm
I run 3rd low when i pull the sled. I have 4:10's and stock t-case to answer the first question
Under construction...
Hansen01
Postby Mark Nixon » Mon Jul 01, 2013 8:42 pm
Hansen01 wrote:I run 3rd low when i pull the sled. I have 4:10's and stock t-case to answer the first question
Your 1000th post wasted answering a question of mine! :lol:
I am honored. :salut:
Postby Hansen01 » Tue Jul 02, 2013 7:57 pm
:lol: Anytime,lol
Hansen01
Return to Competition
Users browsing this forum: No registered users and 73 guests
