Re: '90 W250
Postby 01hillbillycummins » Mon Jul 22, 2013 10:18 pm
Man, i should have subscribed to this thread a long time ago. Some good work in here.
1990 w250 Denny T II pin, 3200 spring, BHAF, DE 4" TBE, 5" lift, 37" toyos, kelderman air ride, 75 gal aux fuel tank
01hillbillycummins
Re: '90 W250
Postby Tacoclaw » Tue Jul 23, 2013 4:17 am
Oh God, whatever you do, don't subscribe!!!
According to RC, sometimes our friendly conversations can be a little rough on your email inbox. :lol:
Re: '90 W250
Postby 01hillbillycummins » Tue Jul 23, 2013 6:01 am
Haha, don't worry, i turned email notifications off a long time ago!
01hillbillycummins
Re: '90 W250
Postby Tacoclaw » Tue Jul 23, 2013 11:15 am
Just in case any of you drive my specific truck here's my blueprints of the blower pulley. This will get you just clear of the accessory belt with my specific fan pulley and mount. I'll get their part numbers later. Also, the smallest hole sits right on the fan threads, I figure you could fit your stock fan back on there if you enlarged it enough to clear the hex. Dunno if the blades would clear the belt though. =\
Also, I'm still not sure if this thing will clear the balancer with a belt on it, 7.5" may be too tall.
Here's the cutter you'll need to make serpentine grooves, the point is actually radiused a bit but you'll just have to experiment that for yourself.
Re: '90 W250
Postby rockbuggy4x4 » Tue Jul 23, 2013 12:19 pm
RCCUMMINS89 wrote:I also put a body lift on anything I personally own (some people don't like the looks, which I can understand), but I can change the starter right through the wheel well, same goes for oil filter, vacuum pump, etc......Oh, and I can fit 9" exhaust through the case if I ever felt the need to.
Yup. Mine has a 3" body lift, and that's exactly how I work on my engine...through the fenders! :lol:
Jimmy
--> '85 cab w/ '89 engine and trans stock with minor pump tweaks and a flatbed. **soon to get lots of goodies**
--> '95 jimmy not so stock
rockbuggy4x4
Re: '90 W250
Postby AHineman » Tue Jul 23, 2013 12:23 pm
Hopscotch, Levi?
Re: '90 W250
Postby Tacoclaw » Tue Jul 23, 2013 12:32 pm
The way I run a lathe it's more like hangman. :lol:
Re: '90 W250
Postby Tacoclaw » Tue Jul 23, 2013 2:57 pm
You've got to know your limits and here's mine.
Re: '90 W250
Postby PToombs » Tue Jul 23, 2013 3:23 pm
That doesn't look like a 7.5 inch pulley to me! Or is the camera way far away? :?
Re: '90 W250
Postby Tacoclaw » Tue Jul 23, 2013 3:27 pm
Practice piece, I'm not as dumb as you think I are. :P
I'll see about having them heat-treat it as well wherever I get it done so to the belts don't wear it down over time.
Re: '90 W250
Postby PToombs » Tue Jul 23, 2013 3:35 pm
I'm not as think as you dumb I am? :lol: That makes sense, why ruin your pulley piece. ;) As for heat treating, are the regular pulleys heat treated? I think they are soft, IIRC, I have dinged them before working around them. Maybe I'm wrong....... ;)
Re: '90 W250
Postby dazedandconfused » Tue Jul 23, 2013 3:38 pm
So are you giving up on trying to cut the grooves your self?
Re: '90 W250
Postby Tacoclaw » Tue Jul 23, 2013 4:08 pm
Yup, no way I'm messing this thing up on the last step. :lol:
Re: '90 W250
Postby ellis93 » Tue Jul 23, 2013 4:22 pm
PToombs wrote:I'm not as think as you dumb I am? :lol: That makes sense, why ruin your pulley piece. ;) As for heat treating, are the regular pulleys heat treated? I think they are soft, IIRC, I have dinged them before working around them. Maybe I'm wrong....... ;)
Your not,they're not hardened. Not a bad idea tho taco
Re: '90 W250
Postby Tacoclaw » Tue Jul 23, 2013 4:45 pm
I noticed a lot of our V-belt stuff at work gets worn out and won't hold belts, I don't think its' nearly as much of a concern with serpentine stuff but I also don't see the harm in it. :grin:
