Project ugly duckling
Re: Project ugly duckling
Postby Tacoclaw » Tue Jul 23, 2013 12:53 pm
Ha!
I forgot how much bigger of a fellow you were than me, it makes sense the Midget wouldn't be enough for you. I guess you can throw in Hiney's Green Weenie as well, two servings for ya. :P
Postby dazedandconfused » Tue Jul 23, 2013 1:03 pm
Lmao that is still just wrong.
Postby PToombs » Tue Jul 23, 2013 3:25 pm
It's not green anymore, the Doc gave me a shot for that siht. ;)
Postby dazedandconfused » Tue Jul 23, 2013 3:36 pm
That is way tmi Pete! Levi looks like he is all ready for you now though.
Last edited by dazedandconfused on Tue Jul 23, 2013 3:56 pm, edited 1 time in total.
Postby PToombs » Tue Jul 23, 2013 3:52 pm
Postby dazedandconfused » Wed Jul 24, 2013 5:42 pm
Well that u joint didn't last long. Going to order one more and try to force a bit more grease in it when I put it together.
Postby ellis93 » Wed Jul 24, 2013 6:41 pm
What exactly happened to it.....crushed pins,worn journals?
Postby dazedandconfused » Wed Jul 24, 2013 6:49 pm
Idk yet I just noticed today it was real sloppy when I was checking my rear brakes. Its tight on the driveshaft side but loose on the rear end side. I think it didn't have enough grease in it to start and it has no grease fitting.
Postby ellis93 » Wed Jul 24, 2013 6:50 pm
Weird :scratch:
Postby skilletky » Thu Jul 25, 2013 7:33 am
i dont know why they would even make a u joint without a grease fitting.
skilletky
Postby rockbuggy4x4 » Thu Jul 25, 2013 8:38 am
dazedandconfused wrote:Idk yet I just noticed today it was real sloppy when I was checking my rear brakes. Its tight on the driveshaft side but loose on the rear end side. I think it didn't have enough grease in it to start and it has no grease fitting.
Are the caps tight in the yoke, or do you mean that's what's sloppy?
skilletky wrote:i dont know why they would even make a u joint without a grease fitting.
Because they are "supposed to last FOREVER" lol but we all know that's not true.
Jimmy
--> '85 cab w/ '89 engine and trans stock with minor pump tweaks and a flatbed. **soon to get lots of goodies**
--> '95 jimmy not so stock
rockbuggy4x4
Postby dazedandconfused » Thu Jul 25, 2013 8:52 am
The caps are tight on the yoke. The caps have slop in them were the universal rides. The needle bearings are gone if I had to guess.
Postby dazedandconfused » Thu Jul 25, 2013 3:04 pm
I pulled it apart and band aided it back together. These are the cups on the rear end yoke. I think it got hot.
Postby ellis93 » Thu Jul 25, 2013 3:13 pm
How's the angle on that shaft?
Postby dazedandconfused » Thu Jul 25, 2013 3:19 pm
Its pretty much straight shot.
