ellis93 wrote:Caleb....have you ever seen what happens to an engine that operates off of that stuff for a long time?
RumbleFish wrote:2 pages and no argument yet? You're doing it wrong.
ellis93 wrote:Depending on how much they've used it,or how long will tell the tale. That siht burns hot and will burn hotter than some motor oils flash point....burning the oil off of the cylinder walls,leading to cylinder wear. I seen a Chevy 350 worn out at 80k and the blossman gas company here use to replace their motors (ford) every 3 to 4 years. crazy stuff
