Phew it's some other strange thing
RCCUMMINS89 wrote:Yep, it starts as a random low idle...especially after it's been worked hard. I'm currently at the point that I gave it a higher idle so that it's not so noticeable when it gets hot. My dad's completely stock truck is starting to do it too.
cmann250 wrote:RCCUMMINS89 wrote:Yep, it starts as a random low idle...especially after it's been worked hard. I'm currently at the point that I gave it a higher idle so that it's not so noticeable when it gets hot. My dad's completely stock truck is starting to do it too.
My idle has always been low, so I don't think it's the pump. Yet. I don't like my truck whistling away at 1000 rpm warming up in the driveway. It's a tightly wound automatic vs. manual thing too.
mhuppertz wrote:How is your fuel pressure? Maybe your lift pump is unhappy.
Cooling your IP should make it run better if that is what the issue is.
