delsilver wrote:The multi switch appears to be a problem on these, a lot of people have put relays in to lessen the load on it and found fewer problems and in some cases brighter lights.
Del
Diesel wrote:Also, just a quick tip. Buy OEM relays. The "Bosch" relay has become chinese. Other universal "Bosch" or "Bosch Style" relays you'll find online (eBay is your best source) will also be chinese. If you get a MOPAR relay that goes under the hood of a vehicle you'll get a quality relay. I used Ram Van relays that actually had a bracket on them - and I bolted it to the inner fender using OEM bolts.
