pyrometer install question
Postby 4thidco » Wed Sep 04, 2013 8:16 pm
I have attached a pic. In the pic in the middle of the manifold before it goes into the turbo, should i drill and tap there? Should i leave the engine running while drilling? This is a 93 w250. Thanks in advance.
4thidco
Re: pyrometer install question
Postby 4thidco » Wed Sep 04, 2013 8:18 pm
I guess i can't put a pic? Can someone please show me where they mounted their probe and drilling instructions?
4thidco
Postby dodgebullit » Thu Sep 05, 2013 2:44 am
This should help. And welcome to the site. http://www.cumminsforum.com/forum/07-5- ... meter.html
dodgebullit
Postby BILTIT » Thu Sep 05, 2013 2:04 pm
Derek B.
BILTIT
Postby 4thidco » Thu Sep 05, 2013 7:34 pm
Thank you both for the help. Should i drill it with the engine running or use a shop vac while drilling?
4thidco
Postby ellis93 » Thu Sep 05, 2013 7:58 pm
A greased drill bit works good.
Postby dodgebullit » Thu Sep 05, 2013 11:18 pm
ellis93 wrote:A greased drill bit works good.
I agree!
dodgebullit
Postby 4thidco » Sun Sep 08, 2013 5:46 pm
Got it done, what a pain that was.
4thidco
Postby simplysmn » Mon Sep 23, 2013 11:19 am
did you pull the Turbo or just grease the drill bit ?
simplysmn
Postby davidandrew » Tue Oct 01, 2013 5:31 am
Leave the engine running while drilling, there will be no problem.
davidandrew
smoke screw?
Postby ByronRACE » Tue Feb 25, 2014 10:03 pm
I don't know what the fear is drilling the exhaust manifold. If you use low speed on your cordless drill, a good sharp cobalt bit, cutting lube of some sort, and patience...the resulting cast iron debris is basically powdered iron. If you blow it away periodically while drilling, there won't be much left to fall into the hole. Then, once you're done...poke a magnet in there if you're worried about it. Worst case, you turn the key and that crap blows through the turbo and out of the exhaust.
I personally would not do this with the engine running for fear of something really crappy happening like having a piece of the drill bit break off and go through the turbo.
Cast iron drills easily. The people that have trouble are using too much speed, a cheap bit, and no lube...slow down, and let the tool do the work. If you see chips or grindings, it's drilling fast enough. Be patient, let it cut, and don't overheat the bit.
ByronRACE
Postby opiebennett » Thu Feb 27, 2014 11:27 pm
ByronRACE wrote:I don't know what the fear is drilling the exhaust manifold. If you use low speed on your cordless drill, a good sharp cobalt bit, cutting lube of some sort, and patience...the resulting cast iron debris is basically powdered iron. If you blow it away periodically while drilling, there won't be much left to fall into the hole. Then, once you're done...poke a magnet in there if you're worried about it. Worst case, you turn the key and that crap blows through the turbo and out of the exhaust.
This is exactly what I did. Engine off, center punched location, pilot drill bit, then ~90% dia bit, then final size. Grease on all bits. Grease on the tap. Shop vac after each step. Anti-size on the adapter that threads into the manifold. Bought brand new bits just for this.
And cast is really easy to work.
Bryan 'Opie' Bennett
91.5 5.9L with 21mm H1C/A518/NP205 Reg Cab LE Pyro/Boost/Trans Temp/BD Fuel Pin/Some fuel screw/Diamond Eye 4" exhaust/B+M Deep Trans Pan/3rd Gen aluminum wheels
opiebennett
Postby lz69 » Fri Jun 20, 2014 5:47 pm
Pretty easy job, just need a good drill and a nice sharp bit.
Mark location of hole on runner and avoid the center divider. For 1/4" fitting use a 7/16" bit, drill in to the manifold till the center of the bit breaks through. blow chips away from surface of hole. grease bit and finish drilling through hole. wipe grease away from surface and use pen magnet to collect stray chips.
Now tap threads with greased tap, remove every couple turns to clear grease and old chips and repeat till fitting fits nicely. Pipe thread is tapered so more you tap it the further your fitting will sit in the manifold.
Finally just hit the thread with a bit of teflon tape or dope to seal it and tighten the plug and probe into place.
lz69
