just picked up a crew cab
Postby oconnellrb » Sun Jan 27, 2008 10:28 am
83 crew cab 4x4 prospector. It had a second gen motor and auto trans (that he kept) divorced to a 205 transfer case. The truck is set up for second gen motor mounts. I have a non intercooled motor and 518 trans that i want to put in, can i put second gen mounts on my motor and bolt it right in?
thanks Ryan
Also need help posting pics thanks!
1983 crew cab 89 motor 1st gen inter cooler hx35 518 auto shift kit and converter divorced 205 transfer case 93 core support.
oconnellrb
Postby Philip » Sun Jan 27, 2008 10:40 am
Yes you can. The block bolt pattern is the same.
Thats nice someone esle did the prep work for you. :D
Postby cummins king » Sun Jan 27, 2008 11:07 am
are you going to biuld it with twins
keep us updated
93 4X4 auto
cummins king
Postby oconnellrb » Sun Jan 27, 2008 11:53 am
twins I'll be happy if i can get it running with the single hx 35 that ive had for a while. where is the best place to get the motor mounts. I also need the part number for the intercooled t-housing and a good place to get the radiator from.
thanks Ryan
oconnellrb
Postby oconnellrb » Sun Jan 27, 2008 12:17 pm
oconnellrb
Postby burnt_servo » Sun Jan 27, 2008 1:46 pm
sweet :) ... is that a short box ?
i've got a dodge crewcab short box / diesel project running in the back of my mind for a long while now .
burnt_servo
Postby PToombs » Sun Jan 27, 2008 1:58 pm
I don't want you to take this personal, but, You Suck! :lol:
I wish I could find something like that! With the prep already done, makes life easy. Looks like you lucked out, good find. 8)
Postby oconnellrb » Sun Jan 27, 2008 2:21 pm
yes its a short bed. as far as i know they never made a crew cab long bed 4x4.
PToombs :lol:
oconnellrb
Postby cummins king » Sun Jan 27, 2008 3:30 pm
it would be one ong truck if it had a long box, there is some heavie duty mounts that they make for us check in part numbers ,
93 4X4 auto
cummins king
Postby burnt_servo » Sun Jan 27, 2008 4:47 pm
oconnellrb wrote:yes its a short bed. as far as i know they never made a crew cab long bed 4x4.
PToombs :lol:
locally there is a '76 2x4 crew cab long box . at least a 3/4 , maybe even a 1 ton . 318 4 speed
it is a former deptarment of transportation truck , so it might have been a special order . from what i could see , the frame wasn't cut and stretched .
i would have bought it if it wasn't so rusty ( there's not much left to weld to too , it's that bad ) .
anyways .... you stepped in something good there :)
burnt_servo
Postby oconnellrb » Sun Jan 27, 2008 6:18 pm
they made 2wd crew cab long boxs but not 4x4
oconnellrb
Postby PToombs » Sun Jan 27, 2008 6:38 pm
I was going to say, I saw crew longs on the Government Liquidation website. After that post, I remember they were 2wd. ;)
Postby cummins king » Mon Jan 28, 2008 6:46 am
so what years did dodge make the crew cabs
93 4X4 auto
cummins king
Postby RumbleFish » Mon Jan 28, 2008 2:38 pm
1985 was the last year of production
Postby Fred S » Mon Jan 28, 2008 5:03 pm
oconnelrb, I've got some 2nd gen motor mounts, if you need some. Dang, don't let me near that truck, I might talk you out of it.
92 W250 LB Crewcab 3" Alcans, NV5600 4x4, 35inch Toyo ATs, some tweaks
2001 Golf TDI TDTuning-Stg4, R520s, SBC, 17/22
94 Toyota Ex-Cab 4x4 (01 ALH(TDI)) TDTuning-Stg4, PP764s, SBC, 17/22
Fred S
