Postby bgilbert » Tue Sep 17, 2013 4:02 pm
CumminsPower59 wrote:I'm hoping that is the case. I am on the hunt now for a M12x1.75 bottom tap...
Got mine from Napa.
Bill Gilbert
Postby CumminsPower59 » Tue Sep 17, 2013 4:08 pm
The have bottom taps? I have access to standard/tapered taps, but not bottom taps...
Postby bgilbert » Tue Sep 17, 2013 5:02 pm
CumminsPower59 wrote:The have bottom taps? I have access to standard/tapered taps, but not bottom taps...
Yes, could have been old stock on the shelf though.
Bill Gilbert
Postby CumminsPower59 » Tue Sep 17, 2013 5:17 pm
Ah, right on.
Postby PToombs » Tue Sep 17, 2013 6:17 pm
Ike, pull the head, have it surfaced. Hopefully the bolt will come out pretty easy with the head off. Tap the holes with the regular tap, then the bottom tap. Wait! If you are putting regular bolts back in, why bottom tap? :roll: Just run the regular tap thru and put it together!
Postby CumminsPower59 » Tue Sep 17, 2013 6:35 pm
Here is the deal I am faced with. The head is a 9mm, and I am sure it is cracked, like most are. Would it still be worth it to have it surfaced? I wanted to buy a new one, but I can't swing it...I was just gonna run a super fine scotch brite pad over it and clean it up a bit...
Postby ellis93 » Tue Sep 17, 2013 6:43 pm
I'd just run it till I could do better,after all it's not really a bad job. Like you said,it's more than likely cracked,it would be a 1out of 100 chance it wasn't from all I've read.
Postby CumminsPower59 » Tue Sep 17, 2013 6:56 pm
That's what I think I am gonna do. Unfortunately, I got a sick child, so this heap is going to have to get put on the back burner for a bit...
Postby Tacoclaw » Tue Sep 17, 2013 8:13 pm
Just cut the majority of the taper off the bottom of a normal tap, that's how I always make mine. Just use a cutoff wheel and keep dunking it in water as you go. If you turn the metal blue it'll be worthless as a tap since it'll be annealed.
Postby 1STGENFARMBOY » Tue Sep 17, 2013 8:41 pm
yup...that's what I do in a pinch. ^ ^ ^ ^ ^ ^ ^
Postby CumminsPower59 » Wed Sep 18, 2013 8:56 am
Well, all the parts are ordered and on the way, hopefully everything will be in by mid-week next week and I can start assembly. I will probably start tearing into it tomorrow morning and see how far I get. I still have a laundry list of things to get done on the truck anyways, so while I am waiting on parts, I can finish up that stuff...
Postby CumminsPower59 » Sun Sep 22, 2013 4:34 pm
Worked on it for a bit this afternoon...hope to finish the tear down tomorrow morning before I got to go in for work...
Last edited by CumminsPower59 on Tue Sep 09, 2014 10:53 am, edited 1 time in total.
Postby CumminsPower59 » Mon Sep 23, 2013 10:19 am
Pictures...
I guess those 135degree 6x11's were spraying WELL into the bowl :lol:
Another shot...
The offending bolt...
Stupid bolt, I win!!!
That bolt spun out fairly easy....whoops :oops:
Last edited by CumminsPower59 on Tue Sep 09, 2014 10:55 am, edited 1 time in total.
Postby dazedandconfused » Mon Sep 23, 2013 10:26 am
Glad it wasn't seized.
Postby RCCUMMINS89 » Mon Sep 23, 2013 11:41 am
Ya, no kidding.
