Doublers....
Doublers....
Postby rb70383 » Sun Sep 22, 2013 11:11 pm
Planning my crew project and deciding if I want to go with a doubler. Going to run 3.54 gears, around 36-37" tires, 93 A518. I was going to run twin stick for the 2wd low option, maneuvering trailers, but realized to just not engage the front hubs for that. :/
However, since I am running taller tires with high gears, I figure the doubler would help offroad.
Now doubler kits require everything Dodge doesnt have. :;-|: Is a doubler worth it? This will also be a roadtrip vehicle so dont want to re-gear the axles lower.
rb70383
Re: Doublers....
Postby warhammer92 » Mon Sep 23, 2013 12:06 pm
I'm on 40s with 4.10s and it does fine cruising on the freeway.in town is a little sluggish.but 4.10s will help take off better and better for towing
87 f350 w/ 92 I/c cummins. 64mm,6x16 inj., dual intake,188/208, m4,300cc pump,PS I/c, marine pistons,mild ported head. Fully built a518 with 1800 stall.
warhammer92
Re: Doublers....
Postby rb70383 » Tue Sep 24, 2013 7:43 pm
Didn't you wish u had a little extra low range offroad? Curious if the basic 2:1 low range is enough off road. I won't mind a little sluggishness on road for highway cruising. Iirc correctly with my proposed tires, it would be equivalent to havi g 3.7-3.8 gears to be around the same on 40's with 4.1
Another build I was reading they guy ran military 39 XML with 3.54. Said be thought 3.73 with be about right. Contemplating a ff14b for that reason.
rb70383
Re: Doublers....
Postby dunes450r » Wed Sep 25, 2013 5:50 pm
i have 33's with 3.07s and it works just great. don't have time to see what that equals with 3.54s but should be somewhat close.
and i'm running a manual btw
dunes450r
Re: Doublers....
Postby warhammer92 » Wed Sep 25, 2013 7:51 pm
What transfer case do you have.I'm running my ford Borg Warner 1345. 4low is way to hard on everything and when I'm off road I stay in 2wd to test my truck anyway
warhammer92
Re: Doublers....
Postby RCCUMMINS89 » Wed Sep 25, 2013 8:49 pm
I used to run 36s on 3.54s..........no issues what so ever. Even at stock power it did just fine at low speeds.
Re: Doublers....
Postby rb70383 » Sat Sep 28, 2013 11:08 pm
I have the np205. My 01 CTD with the auto and 3.54 is great on the highway, so I am kinda spoiled and used to being able to cruise at 70+ if need be. Hell west side of texas, speed limit is 80. Set cruise at 85 and roll.
rb70383
Return to Transmission
