Go Fast Safety
Go Fast Safety
Postby BC847 » Sat Jan 26, 2008 9:18 pm
OK, I recently got my heap up close to 100mph at the track. I pooped pencils for a day or so afterward. :oops:
What's a descent full-faced helmet for the money?
What are y'all doing about drive-shaft loops?
I've not really dug into it. I'm thinking one at the front of the rear/long axle (mine's a 4x4 with a short intermediate shaft). Do I need one fro the intermediate as well?
How are folks addressing the front drive-shaft?
Considering I'm relatively mild in power, any recommendations for the trans (A518 non lock-up)? Is it really necessary here just yet?
Just thinking . . . . ..
Postby LOGANSTANFORTH » Sat Jan 26, 2008 9:39 pm
helmet can be had fairly cheap, driveshaft loops all depends on how much suspension travel you got and how tall the truck is an everything like that, are you running a divorced t-case or a carrier bearing??? the front loop should be within 6 inches of the front u-joint......i would run it in 3rd gear and see how it does, if you are over revving the engine then need to let it shift into OD, i would recommend a lock up converter cause that will let you transfer alot more power in OD.......some trucks slingshot when the converter locks and some dont......
THEY PUT THEM ON A PLANE TO SOME STRANGE AND FOREIGN LAND, THEY SAID GOODBYE TO MOM AND DAD AND HELLO TO UNCLE SAM, THEY NEVER THOUGHT THE DAY WOULD COME WHEN THEY MIGHT HAVE TO KILL A MAN, THEY DID NOT SLEEP A WINK THAT NIGHT BUT THEY WON FOR UNCLE SAM
LOGANSTANFORTH
Postby BC847 » Sat Jan 26, 2008 9:53 pm
In the 8th, it's a toss-up as to whether OD is of benefit. 8.81 @ 75.81. The 4th is 14.16 @ 93.46 at the moment. (1.8 60' marks).
I'm fixing to bolt on a better head and expect to eventually get into the 13's for this coming summer.
The intermediate shaft has a joint at the butt of the married NP205 and a carrier bearing at the tail-shaft end.
The tail-shaft, I'm thinking of a single loop for the forward joint.
Postby RumbleFish » Sat Jan 26, 2008 10:36 pm
www.helmetcity.com
I bought an open face helmet for when I autocross at a local swap meet for $140. Its made by G-Force. If you need a Snell SA rated helmet (I did for track days), you won't find too many cheaper. Does your track require a helmet, or are you doing this on your own? If they don't require one, or are loose with tech (tech at my local-ish track consists of having at least one window to shoe polish your number on) you could get away with a non rated, or a Snell M rated helmet. The M rated will be cheaper, and the non rated cheaper yet. The difference between the SA (specialty application) and M (motorcycle) rating is the SA has a flame retardant lining.
I would seriously reconsider the full faced deal. Have you tried one? I have a fat head, and got somewhat clausterphobic in one. It was too hot, and my nose touching on the front of the helmet annoyed me to no end, so thats why I went with the open face, plus it was cheaper.
Postby LOGANSTANFORTH » Sun Jan 27, 2008 8:41 am
how about a 5 gallon bucket with 2 holes punches it so you can see Rumble.....
LOGANSTANFORTH
Postby BC847 » Sun Jan 27, 2008 8:58 am
RumbleFish,
Back in my motorcycle days I rode with a Shoei full faced helmet.
I managed to wipe-out hard enough once or twice to bust my face pretty good on the inside of the helmet. I can't imagine the outcome had it been less of a helmet.
I don't mind paying for quality where needed.
In this case, I'm taking it upon myself to get and use the helmet. ;)
Postby PToombs » Sun Jan 27, 2008 9:49 am
I'll 2nd the fat head comment! :lol: Beach ball with glasses comes to mind! ;)
Jeff, j/k, you left yourself open for that! ;)
Postby CAJUN 93 » Mon Jan 28, 2008 7:03 am
you'll find any safety stuff you need at either summit or jegs. they'll ship stright to your door
http://summitracing.com/
http://www.jegs.com/
i tend to use summit more but have had great service from both.
daryl
CAJUN 93
Postby BC847 » Mon Jan 28, 2008 9:35 am
Where can I find information as to safety device specifications, such as the safety loops?
Thanks folks. :)
Postby CAJUN 93 » Mon Jan 28, 2008 10:33 am
sfi is the corporation that determines the specs. if you have the time you can dig on thier site http://www.sfifoundation.com/home.html
as for driveshaft loops etc. most diesel orginizations have posted rules for classes that match the et's the class runs. heres dhra's 2007 rulebook.
http://www.dhraonline.com/pubs/dhra-rulebook-v2.7.4.pdf
daryl
CAJUN 93
Return to Competition
Users browsing this forum: No registered users and 79 guests
