CumminsPower59 wrote:I'm fixing too...except the "top hat" spring earned its Airborne Wings...it went flying across the garage a while back and I haven't seen it since...probably gonna look up the part number for it and order one, but its gonna get put in the "new" pump so I can get the old pump going...
I swapped a few things around from the new pump back to the old (non-ic), installed the old pump, etc., now it has issues...mainly same as before, starts to miss at 1400rpm's and gets worse as rpm's increase, along with when the clutch is pushed in when coming off the throttle, it will stumble and die, like the governor will not "catch" it at the right time, feels the same as if you turn the key off. At lower rpm's, i.e. snapping the throttle open by hand, it will come down and "catch", but at real low rpm's, like 300 or so, then bounce back up to idle, which is set at 750rpm. I don't have much time to fart around with this pump, I am going to pull it back off, swap parts back over and run the "new" pump out to S.O.P., where hopefully someone can give me a hand... Return to Conversions & Builds
