Intercooled vs non
Intercooled vs non
Postby 92cummins89 » Sat Nov 16, 2013 12:27 am
Heard tht a non ic cummins produces more hp an two than a ic cummins but it can't hold the power cuz it over heats
Any truth to tht doesn't seem right
1992 4x4, 4” diamond eye exhaust, nv4500, he351cw
92cummins89
Re: Intercooled vs non
Postby cmann250 » Sat Nov 16, 2013 4:16 am
Non-IC trucks have hotter fuel systems, making them slightly more desirable at near stock levels.
They also have a down flow radiator compared to a cross flow in the later trucks. I've never pulled over to cool down, but I kick in my fan more than I'd like since I stuffed an intercooler in front of the radiator.
Postby Tacoclaw » Sat Nov 16, 2013 5:23 am
They run better stock and can be turned up more on stock components. They also have wider piston bowls allowing more timing to be added.
I think the IC cooling system is probably much better than the older stuff. I see no reason why it wouldn't be.
Postby TheSilverBullet » Mon Jan 13, 2014 12:48 pm
Also not ic will have less turbo lag because it doesn't have to shove it through a inter cooler. I personally don't see a need for an ic but I don't tow anything real heavy I just keep an eye on my egt.
Brownie-1990 w250 straight six standard transmission 445k odometer quit in 02 lol
The Silver Bullet-1998 qcsb 12v twins and a 6 speed
Blue bear- 2001 3500 pee pumped 24
TheSilverBullet
Return to Competition
