Does the heater in your truck work?
both inside and out
Postby qmikep » Fri Nov 29, 2013 8:08 pm
I'm not sure if my heater/ac controls are working properly. Because quite frankly, my heater sucks. I've cleaned out the heater box and flushed the heater coreand it didn't change a thing. When I push the "heat" button, hot (actually slightly warm) air only blows through the vents on either side of the transmission tunnel and he upper vents close.
When you push the "heat" button on, do your vents stay open and have hot air blow through them or do they close? And does your trucks heater blow hot air at all?
Thanks,
Mike
qmikep
Re: Does the heater in your truck work?
Postby The_Head » Fri Nov 29, 2013 8:50 pm
Sort of. I think I have a vacuum leak in the brake booster though. The heater controls are vacuum operated I believe. It takes awhile to get warm but it does eventually. I have not cleaned out the ducting yet though.
The_Head
Postby RCCUMMINS89 » Fri Nov 29, 2013 9:17 pm
Mine will cool you out in short order.
If the heater isn't working good, then something isn't right.
Vacuum controls the doo hicky that swaps floor, vent, etc... If it doesn't get hot, I would check your thermostat.
Postby CumminsPower59 » Fri Nov 29, 2013 9:37 pm
Check the operation of the valve that is on the coolant lines...?
Postby qmikep » Sat Nov 30, 2013 10:53 am
Does hot air blow out the upper vents on your guys trucks? Because I can hear the vaccum actuator close the upper vents when I push the heater button, which doen't seem right to me.
qmikep
Postby JimmieD » Sun Dec 01, 2013 8:56 am
I don't know if this relates to 1st Gens but a buddy was having a similar problem and this 'Fix' at the link solved it. Had to access this right above the tranny hump as I recall. Could at least be something similar on the earlier trucks?
http://www.heatertreater.net/magento/in ... 95-02.html
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Postby J-link » Sun Mar 30, 2014 6:33 pm
Mine only blows heat out the vents when I push the vent switch, the heat button blows out the floor and the windshield vents.
My truck would only blow slightly warm air out and I flushed the heater core and put a Cummins 180* thermostat in and it will run you out now
1992 D250- 40hp sticks, DennyT stg2 pin, GDS 60mm whirlygig, ISSpro boost and pyro, a518 sloshomatic
J-link
Return to Body
