nv4500 output shaft
nv4500 output shaft
Postby warhammer92 » Sat Nov 30, 2013 7:48 pm
Can the output shaft of a gm nv4500 work in the dodge nv4500
87 f350 w/ 92 I/c cummins. 64mm,6x16 inj., dual intake,188/208, m4,300cc pump,PS I/c, marine pistons,mild ported head. Fully built a518 with 1800 stall.
warhammer92
Re: nv4500 output shaft
Postby CumminsPower59 » Wed Dec 04, 2013 5:00 pm
You mean mainshaft? Count the splines, I'm not sure what all counts they came with, GM stuff is usually 32 spline, could be others. Most Dodge NV's came with 29 spline outputs...
Postby warhammer92 » Sat Dec 07, 2013 2:08 pm
Yes I meant the main shaft.I know the gms came with 32 spline and that'd what I want but what i need to know is if its a direct swap
warhammer92
Postby CumminsPower59 » Sat Dec 07, 2013 3:07 pm
I don't see why it wouldn't be, but im not positive. Stillsmokin would be the one to ask on that...I know he has done some in depth stuff with NV's and the differences between the early/late, and Dodge and GM versions...
Postby warhammer92 » Sat Dec 07, 2013 3:57 pm
Ok maybe ill pm him
warhammer92
Return to Transmission
