The_Head wrote:I'm not a mechanic, and I kind of hate doing that work when I do do it. I am willing to pay to play if required though. I'd rather find a competant someone who is doing sidework than go through a shop for the reason you mentioned... overhead. I got a coworker who used to work for Ford, this was before the 6.0's came out (he says he is well trained in the 7.3's though), but he will do mechanical work for me for a great rate when he is not hunting.
ellis93 wrote:Closet Ford Lover
Remps wrote:I like them for high speed cruising. Wind it up to the 160 kph speed limiter then turn key to start position for about 5 seconds and you bypass the speed limiter. Stock 6 litres can go around 197-199 kph top speed.
CumminsPower59 wrote:Ellis, at $70 and hour, that is an honest and fair rate in my book, it's when it hits $100+ for general labor is spendy. If someone/shop provides a specialized service, like studs/gaskets on 6.0's, has a good record, and can get the repairs done in a timely manner, sure, I'd probably pay it if I wasn't so broke
I do feel for the guys like you Ellis, small operations that are honest, competent and trustworthy...doesn't seem to be too many left in my area anyways, it's even worse on the commercial side of things...seems most places around here use the "shotgun" method, just slinging parts untill something is fixed, then stick you with the bill
Users browsing this forum: No registered users and 75 guests
