p-pump identification
Postby warhammer92 » Sat Dec 21, 2013 10:51 pm
I traded all my ve stuff today for a p-pump. The three numbers are 906. Anyone know which pump that is
87 f350 w/ 92 I/c cummins. 64mm,6x16 inj., dual intake,188/208, m4,300cc pump,PS I/c, marine pistons,mild ported head. Fully built a518 with 1800 stall.
warhammer92
Re: p-pump identification
Postby CumminsPower59 » Sun Dec 22, 2013 8:18 am
The google machine listed several sites that says its rated at 175 HP.
Postby RCCUMMINS89 » Sun Dec 22, 2013 10:13 am
The 160/175 pumps without a lot of internal modifications seem to max out around that 350cc mark. That includes the normal of fuel plate, afc mods, racking the barrels, etc....
Postby The_Head » Sun Dec 22, 2013 12:02 pm
350 cc's at what rpms? We've seen some VE's do that much fuel, but we all know they peter out, as you spin them faster.
The_Head
Postby RCCUMMINS89 » Sun Dec 22, 2013 1:20 pm
The highest I've ever seen a 12mm go is 330. And that is if you use a test bench that utilizes MASSIVE injectors.
That p pump cc is using std. nozzle outputs on a test bench (I don't know what that size is), but I know that a maxed 12mm ve usually puts out around 275 on those test benches.
Now... the key to utilizing high cc output in the upper rpms in a 160 p pump is using very high inlet pressures (think 40-60+). And then lastly the 160/175 p pumps have an issue due to their camplate design... this is also why they require massive timing, such as the ve does. BECAUSE OF THEIR LOWER INJECTION PRESSURES (still higher than a ve though). Also, this is why they need large injectors to make power....much like the ve does.
Postby warhammer92 » Sun Dec 22, 2013 4:19 pm
The pump has a hundred plate in it now.it already had 3200gsk installed.I plan on doing the delivery valves and possibly changing out the camplate.what would I have to do to use a 215 camplate
warhammer92
Postby RCCUMMINS89 » Sun Dec 22, 2013 4:23 pm
Not sure... starting to get into a realm of me not knowing. IIRC the plungers are different between the pumps, but again now sure. So, I don't know what is involved in just swapping cam plates. IMO if one is going to tear the pump down that far.... might as well go all out and custom everything.
Postby warhammer92 » Sun Dec 22, 2013 4:29 pm
I plan on redoing everything just because I have no idea how many miles are on it and how hard it was beat.i thought it said it was a 908 pump but I looked closer when I got home.some said it could be off a kw
warhammer92
Postby RCCUMMINS89 » Sun Dec 22, 2013 4:34 pm
I'd pm BPonci over on Cummins forum or Comp d. Brad knows IMO more about these pumps than anyone out there. There are some pumps that are ag pumps, etc... that literally aren't worth a terd.
Brad has done 2 of my buddies pumps, when they went away from ve pumps. He is really affordable and can get a ton of fuel out of them.
Postby warhammer92 » Sun Dec 22, 2013 6:03 pm
Hes out of Fortuna right.pretty far drive but ive heard he is good real good
warhammer92
Postby RCCUMMINS89 » Sun Dec 22, 2013 6:14 pm
Correct, can always just ship the thing.
Postby warhammer92 » Sun Dec 22, 2013 6:48 pm
Yeah there's always that.but this thing is going to cost some change
warhammer92
Postby RCCUMMINS89 » Sun Dec 22, 2013 6:54 pm
Ya... buddy shipped his 180 pump from Massachusetts and it ran him like $70.
Postby warhammer92 » Sun Dec 22, 2013 7:03 pm
Thats not bad.but im talking about rebuilding the sucker and adding better parts.but it will be so worth it.good thing its propane season.ive been kept pretty busy in the shop
warhammer92
