Cummins Excursion
Re: Fummins project
Postby RumbleFish » Wed Dec 18, 2013 5:28 pm
Speaking of 10.25s, ive got one out of a 96. 3.54 srw version. I think you need it!
Re: Fummins project
Postby ellis93 » Wed Dec 18, 2013 6:11 pm
dazedandconfused wrote:So other then a bad universal, a fuel leak and crappy mileage the psd runs okay. The salt has done a toll on it though. It will need manifolds and up pipes since they are rotted bad and a oil pan. I'm dripping fuel down the back of the block but nothing in the valley. I'll have to look into that tis weekend. I'll be lucky to get 12mpg its looking.
Its the fuel return that runs under that turbo pedestal. Real common. I think I'll have you covered on parts Andy,it's all on the floor of the shop,I just need ol boy to make a move
Re: Project i bumped my head
Postby dazedandconfused » Sat Jan 11, 2014 5:02 pm
Well me and the old man worked on the Ford some this weekend. I figured out my salt spreader and got the bed working. Dad finally had enough of my procrastination and installed my mud flaps too.
Postby dazedandconfused » Sun Feb 02, 2014 9:48 am
Still tossing the idea of putting a Cummins in this. I really wish some people wouldn't pick up tools.
Postby cmann250 » Sun Feb 02, 2014 9:53 am
That's interesting. Interesting is the best word for it.
Postby 93oneton » Sun Feb 02, 2014 11:00 am
I think some people should have there thumbs cut off so they cant hold tools, then we would have less awesomeness like that!
Shit happens
93oneton
Postby dazedandconfused » Sun Feb 02, 2014 11:07 am
They managed to screw up the snap ring retainers so bad on one U-joint I had no choice but tac the new joint like they did. It will get a new shaft when I rebuild the 83.
Postby PToombs » Sun Feb 02, 2014 12:47 pm
I don't see a problem, the old joint didn't fall out did it? Then it was a good fix. ;)
Postby dazedandconfused » Sun Feb 02, 2014 1:02 pm
No but the bastards were a pain to get out. I just pulled in the house to steam coming from under the hood. It appears they broke a bolt changing the thermostat as well and didn't bother fixing it so its decided to leak. I'm pretty sure the Duck was laughing at me.
Postby PToombs » Sun Feb 02, 2014 1:30 pm
It should! :lol: It should be Found On Road Dead, but you made it back to the yard. I think you just got lucky.
Postby dazedandconfused » Sun Feb 16, 2014 6:49 pm
Well took the guttless bastard to pick up a cab yesterday. I'm less then impressed with this thing each day I drive it. Its way underpowered and gets horrible fuel mileage. I averaged 7mpg yesterday pulling a 16' trailer with a cab on it. Running 65mph top speed sucked also. Guess I'll pick up that 440 I've been watching.
Re: cant make up my mind
Postby dazedandconfused » Sat Feb 22, 2014 1:53 pm
Gutted my new cab today. Need to start prepping my frame and getting ready for chassis paint.
Re: Ford project
Postby dazedandconfused » Sun Feb 23, 2014 10:29 am
Went to the local pull-n-pay today since they were doing there everything you can carry for $80 deal. I picked up doors, some trim and the pedal assembly. I also picked up some little pieces for other projects as well.
Waiting for my taxes to come in to pick up some more stuff. Oh and its getting the Cummins out of the Duck.
Re: Ford project
Postby dazedandconfused » Fri Mar 14, 2014 5:45 pm
I pulled the pcm out of the dump tonight. Apparently its been wet before. I had to pull the e-brake and use a 2x4 and hammer to beat this SOB out.
Re: Ford project
Postby ellis93 » Fri Mar 14, 2014 6:12 pm
Andy you went about that as$ backwards,you should have dropped(peeled the rear of it forward) the inner fender(plastic junk) and removed it by taking out that plate with tje two nuts holding the computer in.
