and so it begins.....
Re: and so it begins.....
Postby AHineman » Sun Jan 12, 2014 6:01 pm
My '90 model has a solid flex plate....are the solid first gen ones any better?
Postby PToombs » Sun Jan 12, 2014 6:02 pm
Thought all the 1st gens had a cut out one? Maybe somebody changed it already?
Postby AHineman » Sun Jan 12, 2014 6:04 pm
I had the trans gone through when I first bought it and the guy that did the work said the early first gens had a solid one and later ones had the cut outs. I don't really know.
Postby Deathrod » Mon Jan 13, 2014 4:36 am
You guys really think I need a better one? I'm not going to be pullin a 10k trailer up a grade with my foot in it or anything.......I think my light weight is easy on the trans stuff even though I get on it all the time. Mild 2nd gens don't have problems with them.....the ole ve doesn't make tons of power. Maybe locked up in od + 60 psi will start breakin stuff.....only one way to find out
Deathrod
Postby dazedandconfused » Mon Jan 13, 2014 7:57 am
You can break flex plates with bone stock 6.5s so I think I would beef it up. I've seen tons of broken stock dodge flexplates hell even my donor truck had one when I built the Duck.
Postby fatty » Mon Jan 13, 2014 11:44 am
You definitely need a better flexplate. The stock flexplate is probably the most commonly broken part on auto first gens. It's only a matter of time, mine lasted about 40-50k of about 275 HP. I was particulary hard on it one night racing my brother and general goofing around, and it broke the next time I drove it.
Postby PToombs » Mon Jan 13, 2014 6:18 pm
Deathrod wrote:the ole ve doesn't make tons of power.
The "torque monster" doesn't make tons of power? :lol:
Postby RCCUMMINS89 » Mon Jan 13, 2014 6:27 pm
60+ psi definitely likes to break stuff....BUT you have one major thing on your side...lack of resistance (lightweight)
Postby Deathrod » Sun Jan 19, 2014 8:15 am
Alright, alright....thanks to all you guys now I'm waiting on the ups guy. I got an sfi steel plate. After doing a lot of reading a billet doesn't flex and cost to much. Wouldn't a stock plate be a good "fuse" in the drivetrain, id rather break and replace that instead of an input shaft.
Deathrod
Postby RCCUMMINS89 » Sun Jan 19, 2014 9:03 am
I like my u joints to be the fuse. Easiest thing to replace.
Postby brandonmgreer » Sun Jan 19, 2014 10:23 pm
^^^like. as long as its not a front one, resulting in a pole vault...
White/black 92 D250 manual conversion, Pump tweaking is about it right now...
95 CCLB 4X4 5 speed being but back together from a wreck
99 Kenworth W900 flat top, Tuned 500 Detroit, BW 75mm 1.32A/R, 5915 injectors, 13 speed, 3.55's
brandonmgreer
Postby Joecochrane » Sun Jan 19, 2014 10:50 pm
Jealous of your car
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
Postby Deathrod » Wed Jan 22, 2014 1:14 pm
Well here it is. The plate is much thicker steel, less cut outs and the ring gear is double welded unlike the stocker. I'm sure I can't break this one. I didn't realize how cheaply made the factory plate is until I had something to compare it too.
Deathrod
Postby DMan1198 » Wed Jan 22, 2014 5:24 pm
That thing is freakin cool.
Postby PToombs » Wed Jan 22, 2014 5:25 pm
Ooooooo, shiney! 8)
