jdiesel_us wrote:So is this spacer worth the trouble to install on an otherwise stock engine?
RCCUMMINS89 wrote:No, that is not true. The spacer may go under the ksb, but still works the same.
The timing spacer does 2 things. First, it allows more travel by spacing off the blocking plate (with ksb, or in your case an actual plate) and allowing further travel. Second, it takes some pre load off of the timing spring and thus allowing a faster timing advance.
dbshelton wrote:This is one mod that sounds like it's hard to top. I'll try one some day.
