Re: Pete got blown!!!
Postby DodgeFreak » Sat Jan 18, 2014 12:13 pm
I really need to do this to mine....but its all about the mighty dollar and with a wife and 2 kids, and her wanting a 3rd the dollar is gone...lol
Re: '90 W250
Postby cmann250 » Sat Jan 18, 2014 1:03 pm
Watching for post-install impressions.
Re: '90 W250
Postby Tacoclaw » Sat Jan 18, 2014 1:07 pm
It'll be a bit, I'm going to try ditching the factory proportioning valve. Hooking the front lines straight through, then using a universal adjustable prop valve for the rear line. Dunno if it'll work or not, but the valve was only $40 and I had to redo the lines anyway.
Hopefully I can get it together this week sometime, but the weekend is much more likely.
Re: '90 W250
Postby PToombs » Sat Jan 18, 2014 7:11 pm
DF, sounds like a good time to sneak down and get fixed! ;)
Re: '90 W250
Postby PToombs » Sat Jan 18, 2014 7:12 pm
Levi, don't you own a socket to tighten those with? :roll:
Re: '90 W250
Postby Tacoclaw » Sat Jan 18, 2014 8:33 pm
They're directly above the steering column, pedals and wires all over the place around them. :(
Seriously though, after building my own twin turbo kit and fabbing a blower up, it really never hit me to try a ratchet. I'll give it a shot tomorrow. :grin:
Re: '90 W250
Postby Tacoclaw » Sun Jan 19, 2014 2:59 pm
Dun
Dun
Duuuuuuuuuunnnnnnnnn....
Apparently I kept every single piece besides the TV cable and one section of shift linkage. I can bend up another linkage rod, but I'm not sure what to do about the cable yet. I ditched the setup it used to mount to.
Re: '90 W250
Postby PToombs » Sun Jan 19, 2014 4:40 pm
Ewwww, going all sissy on us! :roll:
Postby CumminsPower59 » Sun Jan 19, 2014 4:56 pm
DodgeFreak wrote:I really need to do this to mine....but its all about the mighty dollar and with a wife and 2 kids, and her wanting a 3rd the dollar is gone...lol
I might still have one or two hydro boost units left over from SOP, they are GM units.
Re: '90 W250
Postby cmann250 » Sun Jan 19, 2014 5:13 pm
Who's flex plate TacoBell? It isn't factory.
Re: '90 W250
Postby Tacoclaw » Sun Jan 19, 2014 5:32 pm
It's not permanent, Pete. Just to throw down a couple times to shut some buddies up.
IF it makes it a little easier to mess with people on the street, it may stick around some, but I never drive anything with an auto too long. I hate them.
Cmann, that's the factory flex plate AFAIK. Dad never had the trans out when he had it and I only had it out for the TC and to swap to a 'rag.
Re: '90 W250
Postby cmann250 » Sun Jan 19, 2014 5:39 pm
Hmmm... All the factory flex plates I've had had were like this:
I like the look of yours a lot better.
Re: '90 W250
Postby dazedandconfused » Sun Jan 19, 2014 5:41 pm
I'll look in the shed Levi because I may have a kickdown cable.
Re: '90 W250
Postby cmann250 » Sun Jan 19, 2014 5:48 pm
If Andy doesn't have one, I have one that you may be able to rig. It has the slot cut off of it.
Re: '90 W250
Postby Tacoclaw » Sun Jan 19, 2014 5:49 pm
I'm looking into that actually, I may just put it on a pull cable in the cab or something. Leave it at 1/2 travel while I'm driving around and yank it to full bore for racing. I'll have to look into how they work. I saw a thread here somewhere.
