BobS wrote:The most common leak sources are the roof lip where the sealing compound reaches the end of its life and cracks or flakes off; the windshield area around the gasket rots through in a corner near the top of the windshield or the gasket seal itself becomes compromised; the seam which I believe you already found in the bottom corner of the windshield in the cowl area; the cowl crack problem; or the useless vent that is in the kick panel side below the dash. This vent acts as an overflow for the debris dam that forms in the bottom of the cowl. Then there are the roof marker light gaskets that leaks in some cases.
