ASTG manual wrote:Front clutch: 0.067"-0.134"
Rear clutch: 0.032"-0.055"
PToombs wrote:Isn't the clearance set with the snap ring? It was on my 47RE on the front clutch pack, meaning the one closest to the front, can't remember which it actually is right now. I'm glad I got an extra trans with the truck, I rebuilt the extra, then robbed the snap ring from the one in the truck when I swapped them.
I'd say pull it again, it will be cheaper and better in the long run. You can put in a worn old one or several to give some clearance if you need to.
Users browsing this forum: No registered users and 62 guests
