how do i tell what trans i just bought.
Re: how do i tell what trans i just bought.
Postby Joecochrane » Mon Feb 03, 2014 1:02 pm
It also has a hole machined into the face of the input shaft. So I'm really hoping it's a rh
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
Postby DodgeFreak » Mon Feb 03, 2014 1:05 pm
If so you just stole it....
Postby DodgeFreak » Mon Feb 03, 2014 2:25 pm
Also a way to tell.
46rh
47re
Postby Joecochrane » Mon Feb 03, 2014 2:49 pm
Ate those the input? Guessing so
Joecochrane
Postby cmann250 » Mon Feb 03, 2014 3:21 pm
Joecochrane wrote:Ate those the input? Guessing so
Yes.
DodgeFreak wrote:If so you just stole it....
I have done better, but I consider myself a near-professional :lol: :lol:
Postby DodgeFreak » Mon Feb 03, 2014 3:34 pm
:lol: :lol: . wouldn't that suck.....come out to your truck and the transmission is gone.....2wd with two people on the street I bet you could have one out in a couple minutes if you cut everything and left the converter lol.
I have gotten one for 40 bucks but the case was shattered lol. I gutted the main case and kept the hard parts and the od.
Postby Joecochrane » Mon Feb 03, 2014 3:40 pm
I'm pretty good at a hustling and swindling truck parts. Last saturday I sold 4 38" tires drove half an hour to buy 5 42" inch tires that were in better shape and made 100 bucks. I let both partys name there price. Just got lucky.
Joecochrane
Postby txs » Mon Feb 03, 2014 4:53 pm
47rh and 48re shafts looks like the second one, too.
txs
Postby Joecochrane » Mon Feb 03, 2014 8:02 pm
Based on the shaft pics it's a 518 bummer. But still better than my current setup. Gonna do a full manual vb kit good converter and slap her in.
Joecochrane
Postby Sutter1stgen » Mon Feb 03, 2014 10:17 pm
You won't be disappointed with the A518. Take it from a guy that commuted 2.5 hours one way with a 727.
Having a extra gear opens up a bunch of possibilities. Like optimizing your take off gearing, and still lowering your cruising rpm.
Eric
Sutter1stgen
Postby Joecochrane » Mon Feb 03, 2014 10:23 pm
Truck never see the highway it's on 42" tires and gets trailered when i take it anywhere it's just a toy.
Joecochrane
Return to Transmission
