Diesel Power Magazine 1st gen buildup
Postby ford69557ci » Fri Feb 08, 2008 7:14 am
i know it has 1400 on sunoco 120 but thats engine not at the wheels. and due to the fact its a little cube small block it only come in at 970 on the torque end of things. but with the new heads and little larger turbo than last year it might be up there a little higher
ford69557ci
Postby DTanklage » Fri Feb 08, 2008 10:49 am
so comparing the torque and traction problems your s-10 has (had) it would be the same traction issues a 500 hp 1000 ft # diesel has
leavin anyways
on the big end gonna be way harder to hook the small block
out here we have the pacific street car assoc
they use motors like yours in 3k # cars and limit them to 10" tire
high 8's all the way down to high 7's
crazy stuff
DTanklage
Postby 75Dodge » Fri Feb 08, 2008 11:37 am
Does the removal of the AFC lever affect fuel mileage at all?
75Dodge
Postby DTanklage » Fri Feb 08, 2008 12:59 pm
nope
but you have to drive the truck diff or it will
lol
DTanklage
Postby 75Dodge » Fri Feb 08, 2008 1:49 pm
Does it give better off the line performance? More to the point, what exactly does the removal of the lever do, and what can one expect from performing the mod?
75Dodge
Postby DTanklage » Fri Feb 08, 2008 2:07 pm
which tranny do you have?
gear ratio?
tire?
what mods you got done to truck?
all of these factors affect the answer to your questions
DTanklage
Postby cummins king » Fri Feb 08, 2008 4:35 pm
most trucks this will help in the botom end, this mod alows the most fuel through a stock pump
93 4X4 auto
cummins king
Postby DTanklage » Fri Feb 08, 2008 6:17 pm
it actually increases fuel all the way thru - but most noticable at the bottom
if you have a turbo that is already near the edge of the map takin that lever out will push it past its limits
DTanklage
Postby 75Dodge » Fri Feb 08, 2008 6:19 pm
I have an 89 dodge D-250 w/ the 5.9. It has approximately 320,000 miles on it. I rebuilt the injection pump with new gaskets and seals because it developed a leak at the distributor head. Automatic tranny. Everything is stock. So it's JUST like the one in Diesel Power's build-up.
75Dodge
Postby DTanklage » Fri Feb 08, 2008 7:10 pm
never messed with that combo but i imagine the auto is trickier to drive w/o the afc than my stick
just pretend you are driving a 231 cu in v-6 with a 1150 dominator on it
you wouldnt floor that right off the line cuz if you did it would stall
same principle
DTanklage
Postby cummins king » Fri Feb 08, 2008 7:19 pm
haha thats twisted dud :lol:
93 4X4 auto
cummins king
Postby JD730 » Sat Feb 09, 2008 7:27 am
DTanklage wrote:never messed with that combo but i imagine the auto is trickier to drive w/o the afc than my stick
same principle
LOL, you gotta sneak up on it, can't flat foot it or you'd put the fire out, big enough injectors would do that at least.
I can't comment on driving any auto without the AFC lever, but mine with a tight converter is terrible with the AFC lever and my custom pin setup to pull as much fuel out of the low end as I can. You still have to sneak up on it, it won't put the fire out, but it will put the lights out behind you.
Don,
Your comment on the turbo is right on, just injection pump tweaks push the baby H1C off the map, which in turn puts the EGT's into unacceptable territory.
I guess the biggest question before you remove the lever is what do you use the truck for. Working it or playing around? I think a truck that works/tows needs to have it , a play truck, do anything you want.
Mike
The "Rattle Box"
JD730
Postby ford69557ci » Sat Feb 09, 2008 10:48 am
i was towing without the lever in mine but i had the water it to keep the egt down on hills
ford69557ci
Postby 75Dodge » Sat Feb 09, 2008 11:11 am
Guess that means I hafta get a pyrometer kit... Anybody want to sell one? :lol:
75Dodge
Postby DTanklage » Sat Feb 09, 2008 11:18 am
yes, you do
if ya get a snow stg III water kit it comes with pyro and boost gauge
an excellent way to justify spending 500 bucks on water
DTanklage
