93 w250 aka The Roo Hunter
Re: 93 w250 aka The Roo Hunter
Postby ellis93 » Wed Feb 19, 2014 6:52 pm
DMan1198 wrote:It's sitting in my shop. Could probably do with being balanced. Wanna buy it?
Pm me with why you think it needs balancing and what you figure it's worth.
Postby PToombs » Wed Feb 19, 2014 6:53 pm
What was the deal with the street pic? You get a ticket for excessive smoke?
Postby DMan1198 » Wed Feb 19, 2014 7:26 pm
It was a red light camera in St. Albert. Caught doing 76 in a 60 zone. I thought it was going red so I stepped on it. I really liked the picture they took
Postby CumminsPower59 » Wed Feb 19, 2014 8:11 pm
I think the picture looks pretty cool :mrgreen:
Postby RumbleFish » Wed Feb 19, 2014 8:12 pm
If it smoked a tad more, they wouldnt have had your plate number!
Postby DMan1198 » Wed Feb 19, 2014 9:22 pm
RumbleFish wrote:If it smoked a tad more, they wouldnt have had your plate number!
That's what I thought when I saw the picture
CumminsPower59 wrote:I think the picture looks pretty cool :mrgreen:
I agree with you whole heartedly. I actually took that picture immediately after opening the letter
Postby DMan1198 » Thu Feb 20, 2014 2:41 pm
Anyone know where I could get a good adjustable external wastegate?
Postby sundaybacon » Thu Feb 20, 2014 4:50 pm
http://jgsturbo.com/wgpg.html
He is kinda local to me. I have the BOV. Nice pieces.
If I ever run an e-gate, I'll buy his.
sundaybacon
Postby DMan1198 » Thu Feb 20, 2014 5:15 pm
Those look cool. Do you happen to know their actual opening pressures?
Postby opiebennett » Tue Feb 25, 2014 10:33 pm
Nice project!
Have you had it on a dyno to see where you are at?
Bryan 'Opie' Bennett
91.5 5.9L with 21mm H1C/A518/NP205 Reg Cab LE Pyro/Boost/Trans Temp/BD Fuel Pin/Some fuel screw/Diamond Eye 4" exhaust/B+M Deep Trans Pan/3rd Gen aluminum wheels
opiebennett
Postby DMan1198 » Wed Feb 26, 2014 10:09 am
It sat on a dyno for like 15 minutes, but was sucking so much air into the fuel system it couldn't get a proper run in
Postby DMan1198 » Fri Mar 07, 2014 7:42 am
Got my flanges, and piping to do my compounds. Just need to get a bit more steel and I can start fabricating
Postby DMan1198 » Sun Mar 09, 2014 8:29 pm
So here's where The Roo Hunter has been sitting all winter
This afternoon I grabbed a couple of shovels, and dug her a path so I could pull her into the shop. Once there I pulled my turbo and downpipe, then noticed just how much rust had formed on my steed speed.
then off came the manifold
I decided to media blast my manifold, so into the cabinet it went (I didn't take a picture of it after because it isn't all blasted (my cabinet is really lame and requires way more effort than I was willing to expend))
So I stuffed the manifold back on upside down, tried and failed to get the short studs off, so I tossed my s480 in there, threw my spacer on, followed by my s300. since one of my studs went in wrong initially it's long enough that I could put a nut on even with the spacer, and cinch it down
See. The steed speed is all silvery rather than the standard black. Then I grabbed some of the piping I got last week and got to work figuring out how to route it. 3 cuts later, and voila
And that's where I stopped for the night. I'll try to get the steel for my hotpipe tomorrow and get a start on that
Postby Sutter1stgen » Sun Mar 09, 2014 10:58 pm
Good progress. I've been mulling over thoughts of my next compound build.
Eric
Sutter1stgen
Postby DMan1198 » Thu Mar 20, 2014 6:36 pm
so a bunch of goodies showed up today. First and foremost my 400gph waterman lift pump came in 8)
along with my universal fuel filter setup (with 1/2" fittings :thumright: )
that'll be going on pretty quick so I can try to get the old girl to fire up. then I checked the mail on the way home, and my manifold studs had come in :D
those are also going on right away. unfortunately I can't use one of them because I stripped the threads on of one of the holes in the head so it's a bigger size than the studs, but it won't matter after I get the new head (whenever that is) also the steel for my hotpipe isn't here yet so I'm stuck where I am on that front
