155* injectors
155* injectors
Postby DodgeFreak » Wed Feb 26, 2014 10:26 am
I bought nozzles that I'm going to set up. they are a 155* nozzle going into a 92 cummins. What all will I need to do to make them perform the best. thin washers, up the pop pressure for better atomization? bump the timing a tooth.
As of right now the pump is maxed with a dennyt stage 2 pin. turbo is stock as of right now until I get my 351 machine work ironed out.
Re: 155* injectors
Postby AHineman » Wed Feb 26, 2014 10:48 am
More timing will make them spray outside the bowl I'd think. Thin washers may help some.
Re: 155* injectors
Postby RCCUMMINS89 » Wed Feb 26, 2014 12:44 pm
Thinnest washers available, mild timing, and bump pressure up a little bit.
Re: 155* injectors
Postby Kasper Cummins » Wed Feb 26, 2014 4:25 pm
Why 155*, if you don't mind me asking.
92 W250 club cab
Kasper Cummins
Re: 155* injectors
Postby DodgeFreak » Wed Feb 26, 2014 4:40 pm
RCCUMMINS89 wrote:Thinnest washers available, mild timing, and bump pressure up a little bit.
That's what I was figuring but I haven't really delt with these before. I figured I'd bump them up to what PODs are and try it...I can always pull them out and reset them.
Kasper Cummins wrote:Why 155*, if you don't mind me asking.
I got them cheap enough. They are DDP stage 4's and I really didn't know they was a 155 until after I got them and was looking them over. I've read they are a good nozzle but I didn't do to much digging on the spray. I'm planning on building the engine to a marine bowl later on but I need to get it up and running in my truck first.
