Hello from Kansas! Picked up a 92 D350 automatic up about 3 weeks ago and so far I'm enjoying it. Truck has somewhere over 218k miles, Danny stage 2 fuel pin and the fuel has been turned up some. Transmission needs work as it is slipping pretty bad, and a lot of the electronics on the truck dont work all that well. Most of the wiring is not in good shape on the truck. Its not in the best shape, but I paid $1200 for the truck and had to replace the starter. Bought the truck mostly for the cummins, but driving it around and looking at it all the time really makes me want to keep it together. But it really needs a lot of work.
Day I drove it home
The PO had the exhaust coming out right behind the front tire and fumes were getting in the cab so I put an 8" stack on it that I was going to use on my 85 Chevy crew cab k30 with a Cummins swap but decided to put it on the D350.
Just basically been working on it to keep it going. All the gauges on it don't work so I have replaced them with mechanical ones and just have them temporarily mounted. Over drive was not working so I have that hooked up to a toggle switch, but other than that the truck runs and drives really good.
