Replacing my rear crankshaft seal . . . and other stuff . .
Re: Replacing my rear crankshaft seal . . . and other stuff . .
Postby ellis93 » Sat Mar 15, 2014 6:49 pm
Me too.....cylinder head bolts,rod bolts,main cap bolts :lol:
Postby dazedandconfused » Sun Mar 16, 2014 6:27 am
I torque smaller bolts or bolts going into aluminium. Sometw I underestimate my own strength.
Postby BC847 » Sun Mar 16, 2014 2:16 pm
PToombs wrote:You torqued the bolts? With a torque wrench and everything? :shock: Wow. I mean, just wow.
:lol: :lol:
Glad you got it going and it works good!
I torque all the bolts. That's just the way I am. :shock:
I figure it's a fastener that's selected by it's intended load. Just as well pull it up for its worth. The vast majority of those I removed during this adventure, were still quite tight (been there over a year ago +/-). :)
I'm thinking of going to the beach this coming weekend. That will tell me how these new injectors are doing, with my current timing-tune, with a known highway driving trip. I'm thinking they're gonna kinda blow. :oops:
Postby RCCUMMINS89 » Sun Mar 16, 2014 2:42 pm
BC847 wrote: I'm thinking they're gonna kinda blow. :oops:
Little smoky on the highway?
Postby BC847 » Sun Mar 16, 2014 2:50 pm
Anything above 1800 or so engine RPM has things fairly clean. That's assuming an empty truck, with the turbo giving perhaps 10 ~ 15 psig of boost. Light throttle stuff.
Accelerating from a stop-light is a challenge keeping things clean.
It's the nature of the beast.
Postby BC847 » Sun Mar 16, 2014 2:52 pm
I'm still sorting the timing thing. Any full throttle stuff above 2000 RPM is very clean. Light-grey stuff (lots of it of course).
Postby oldestof11 » Fri May 16, 2014 4:12 am
Hey BC. How much time do you have in this? I need to do mine and was hoping for a weekend time frame to change it out.
Postby BC847 » Fri May 16, 2014 6:25 am
Pretty-much all weekend. Seeing as you've a 2wd, it should be a lot quicker. But you've still got to pull the trans . . . . .
Postby fatty » Fri May 16, 2014 6:57 am
If you have a buddy help it could be done on a Saturday pretty easily. My brother and I swapped my converter in about six hours total.
Postby DodgeFreak » Fri May 16, 2014 8:20 am
I had my cousins 98 2wd trans out in 3 hours working by myself. so you should be able to get it done on a weekend I'd think as long as the bolts come out alright.
Postby oldestof11 » Fri May 16, 2014 1:42 pm
I'll be using a 3/8" Milwaukee Fuel impact to help.
Do I need that drift tool?
Postby PToombs » Fri May 16, 2014 5:28 pm
3 hours? :shock: It only takes me about an hour and a 1/2!
But then I've had mine out 6 times in the last 3 years and most of the bolts are missing and the rest are replaced with Velcro. :mrgreen:
