Fred Average wrote:Thanks ALL VERY much for the most helpful info.
Think I've found some 2010 OEM Dodge aluminum ones.
Fred Average wrote:Thanks,16x6 huh?
Learned that the 4WD's have bigger OD studs so running those wheels,steel or otherwise wasn't an option as the 2WD lug nuts go too deep into the seat/taper,plus can't then attach the center hub caps which use the 4WD lugs to retain them/hold them on!
