Late Model OEM 8 Lug Wheels That Work/Fit 1st.GEN.Trucks?
Postby Fred Average » Thu Mar 27, 2014 11:52 am
Hi :) I understand that on my 1992 D250 2WD I have 8 on 6.5 lug pattern wheels.
Ideally I'd like to get a 16x8 or 1" wider (over the OEM SIZE) steel rim to properly fit a wider 275/285/? and 85 series road tire.
Additionally,I understand Chrysler went to a metric lug pattern,"changed the game" like Ford did in 1997/later on,screwing up the "good old days" of all 8 lug applications interchanging respective of the hub ID on said rims.
AKA: Dodge and Ford interchanged,GM had a smaller ID hub "hole".
So my question is what late model wheels,Ford,MOPAR,etc will bolt on?
Steel,Aluminum or otherwise?
Thank You. :)
:D ~Fred~ :o
Fred Average
Re: Late Model OEM 8 Lug Wheels That Work/Fit 1st.GEN.Trucks?
Postby cmann250 » Thu Mar 27, 2014 2:22 pm
The '97 and older Ford steel rims are 16" x 7". Your Dodge hubcaps and trim rings may not work though.
My personal favorite is the '97 and back factory Ford aluminum rim. They are also 16"x 7".
Just pretend it's all blue with no rust :lol:
Postby oldestof11 » Thu Mar 27, 2014 4:30 pm
Chevy up to 2010, ford up to 97, and Ram up to current will fit the pattern.
Note, Chevy hubs are smaller but any aftermarket company makes them interchangeable.
Postby Sutter1stgen » Fri Mar 28, 2014 2:05 pm
I'm a big fan of the obs ford alcoa wheels.
Caleb… if I take my glasses off, slightly cross my eyes, and squint!!!
She's a beut!!! Lol
Eric
Sutter1stgen
Postby DMan1198 » Fri Mar 28, 2014 5:36 pm
I think it's a good lookin truck Caleb. Paint and all
Postby dazedandconfused » Fri Mar 28, 2014 5:41 pm
Best pic I have of the Smurf. Lol
Postby Fred Average » Sun Mar 30, 2014 10:49 am
Thanks ALL VERY much for the most helpful info. :o
Think I've found some 2010 OEM Dodge aluminum ones. :)
Fred Average
Postby dazedandconfused » Sun Mar 30, 2014 10:54 am
A few guys on here run third gen wheels with 1.5" spacers and they look good
Postby CumminsPower59 » Sun Mar 30, 2014 7:14 pm
Best side shot of mine...3rd gen wheels with 1.5" spacers
Postby opiebennett » Mon Mar 31, 2014 10:25 pm
Fred Average wrote:Thanks ALL VERY much for the most helpful info. :o
Good choice! I like my 3rd gen wheels.
viewtopic.php?f=31&t=14856
Bryan 'Opie' Bennett
91.5 5.9L with 21mm H1C/A518/NP205 Reg Cab LE Pyro/Boost/Trans Temp/BD Fuel Pin/Some fuel screw/Diamond Eye 4" exhaust/B+M Deep Trans Pan/3rd Gen aluminum wheels
opiebennett
Postby Fred Average » Tue Apr 01, 2014 1:41 am
Hi All... :cheers: I can't thank you all enough for the great pictures and info to help ID said rims!
Looks like I might have found a set of the exact ones I like,the Alcoa round hole type off a Ford.
Thank You All ....Very Much! :bball:
Fred Average
Postby Fred Average » Tue Apr 08, 2014 11:28 am
Thanks for all the great info and pictures :)
Well,I'm still looking for wheels and a question... :shock:
Do the 2WD diesels come with wider steel rims than the gas 2WD's?
In pictures I've seen they look deeper :)
I'd be happy with 4 of those!
Any input appreciated,Thank You!
Fred Average
Postby CumminsPower59 » Mon Apr 14, 2014 3:33 pm
As far as I know, they are the same 16x6 steel wheels.
Postby Fred Average » Tue Apr 22, 2014 7:28 am
Thanks,16x6 huh?
All the same width?
A neighboring rancher has a Cummins 2WD & his wheels look wider in relation to how much deeper the hubcap sits into the wheel.
Figured I'll find a set of 6's /stock rims then & have 'em widened unless someone can suggest a good aftermarket source.
Anyone deal with Stockton Wheel or Pete Paulsen?
I understand they make wheels... :roll:
Learned that the 4WD's have bigger OD studs so running those wheels,steel or otherwise wasn't an option as the 2WD lug nuts go too deep into the seat/taper,plus can't then attach the center hub caps which use the 4WD lugs to retain them/hold them on!
:oops:
Fred Average
Postby DodgeFreak » Tue Apr 22, 2014 10:13 am
Fred Average wrote:Thanks,16x6 huh?
:oops:
I don't follow what you're saying. I've ran the same wheels on my 2wd as my 4wd.
