fresh getrag rebuild now not shifting
Postby lopez dodge » Mon Apr 07, 2014 4:03 pm
Would messing up the preload cause not to go in gear ?
1991.5 ..getrag super40. 40,horse injectors,4"to 6" exhaust , bhaf 2nd gen intake,custom pin timed to the head ..1/4 14.9@93mph 5,500' with a little propane
lopez dodge
Re: fresh getrag rebuild now not shifting
Postby ellis93 » Mon Apr 07, 2014 6:31 pm
In which gear? All gears? Hung in neutral?
Postby DMan1198 » Mon Apr 07, 2014 7:17 pm
When I did mine it was the shift forks not quite in the right place. It required pulling the top cover off again and fiddling with it
Postby lopez dodge » Mon Apr 07, 2014 10:35 pm
Really first second third
No binding or grinding just not engaging
lopez dodge
Postby ellis93 » Tue Apr 08, 2014 3:20 am
I don't think that's preload related,that sounds like a top cover issue.
Postby lopez dodge » Tue Apr 08, 2014 6:31 am
I can yank the top cover through the floor , i'll check that before i pull the trans and t-case again .
sat. was a REALLY long day. 12hr in the garage by myself , by the time reassembly came the mind was mush, couldn't figure out what went wrong.
lopez dodge
Postby lopez dodge » Tue Apr 08, 2014 8:15 am
found out my MAJOR !@$#!@$# instead of setting .006 i set .06 on preload top cover is perfect.
lopez dodge
Postby ellis93 » Tue Apr 08, 2014 10:36 am
Oh boy, yeah that would probably lock one down :lol:
Glad you got it :thumleft:
Postby bgilbert » Tue Apr 08, 2014 11:53 am
lopez dodge wrote:found out my MAJOR !@$#!@$# instead of setting .006 i set .06 on preload top cover is perfect.
How did it feel when you rotated everything? Even move at all? lol
Bill Gilbert
Postby lopez dodge » Tue Apr 08, 2014 1:48 pm
Yeah it moved but using pipe wrench on t-case coupling
:oops:
lopez dodge
Postby bgilbert » Tue Apr 08, 2014 6:17 pm
lopez dodge wrote:Yeah it moved but using pipe wrench on t-case coupling
:oops:
Yeah that's a little tight :lol: .
Return to Transmission
