winkgnz wrote:I had the same problem about a year ago, it turned out to be the VSS (vehicle speed sensor) was bad. I wnet through three of them from NAPA and one from CarQuest only to find out that the aftermarket ones are JUNK!
Go to your local dealership and and hopefully you can still get one from them. that is what I had to do. Also if it's a 4x4 make sure that the ratio adapter on the side of the transfer case is still working as that was also bad on mine.
