Oring
Oring
Postby cougar » Sat Apr 26, 2014 9:37 am
Does anyone happen to know the specs or better yet a part number for the oring that goes on the oil supply line adapter that screws on the turbo?
01 2500 "the work truck".
cougar
Re: Oring
Postby Black93 » Sat Apr 26, 2014 5:13 pm
Quickserve shows part# 3037236 $5.10 :shock:
Black93
Re: Oring
Postby cougar » Sun Apr 27, 2014 10:08 am
Thank you very much! I need to go by Cummins anyway for some gaskets.
cougar
