cheap monster turned money pit ;)
Re: cheap monster turned money pit ;)
Postby RCCUMMINS89 » Tue Mar 25, 2014 12:32 pm
Pretty sure that is the closest hp/tq numbers I've ever seen... making that at 5000rpm by chance?
Postby motorwood » Fri Apr 04, 2014 7:53 pm
It was around 4000.
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Postby motorwood » Sat May 10, 2014 3:51 pm
Dyno'd today 915/1454
motorwood
Postby AHineman » Sat May 10, 2014 5:18 pm
Congrats on the awesome numbers!
I see the sig says broken 5th gear, but I can't remember for sure, are you still running an nv4500?
How bad is it crying over having that kind of power run through it?
Postby motorwood » Tue May 13, 2014 4:31 pm
Yes, nv4500. Its fine. Just avoid 3rd and 5th gear and it holds up pretty good. Lot of hooks on that thing.
motorwood
Postby motorwood » Tue Apr 05, 2016 5:43 pm
Been a long time since I been on here. Mostly been busy breaking stuff, fixing stuff, getting banned from street pulling class. Did make 1008hp all fuel with a single last year. Digging around to get some front weight bracket ideas.
motorwood
Postby ellis93 » Tue Apr 05, 2016 6:33 pm
How'd you get banned from there? Inquiring minds want to hear the story :lol:
Postby motorwood » Tue Apr 05, 2016 7:21 pm
I posted dyno results on Facebook. It wasn't like I dominated the class, only won a couple times per season.
motorwood
