Dash warning lights stay on
Postby Keith Anderson » Thu Feb 14, 2008 2:33 pm
I have a '90 D250. Recently the warning lights on the dashboard would not go off after starting the truck. Took the truck to real guru on 1st gens. After doing the usual electrical checks and finding no faults, he happened to notice the interior light above the rear cab window had a burned out bulb. He replaced the bulb and solved the waring light problem.
Keith Anderson
Postby cummins king » Thu Feb 14, 2008 3:20 pm
some kind of sort
93 4X4 auto
cummins king
Postby flashgordon » Thu Feb 14, 2008 3:44 pm
That is strange..........What waring light was on????
Flash
flashgordon
Postby gear jammer 91" » Thu Feb 14, 2008 5:08 pm
I would guess you have a bad ground somewhere. Electricity will go strange places when it's normal path is interrupted. :shock:
01 LB7
gear jammer 91"
Postby PToombs » Thu Feb 14, 2008 5:10 pm
I vote for the bad ground too. The bulb out just made it obvious you have a problem. ;-)
Reply to flashgordon
Postby Keith Anderson » Fri Feb 15, 2008 4:49 pm
All the warning lights stayed on. The brake lite had been staying on intermittently, but would go off shortly after driving the truck, prior to the lites staying on all the time.............................................bluedodge
Keith Anderson
Keith Anderson
Return to Electrical
