Steed speed manifold
Re: Steed speed manifold
Postby 93flatbed » Fri May 23, 2014 5:39 pm
I have a JGS 50mm I'm going to run.
93flatbed
Postby Tacoclaw » Fri May 23, 2014 7:13 pm
I was running an S362/S475 combo at the time with 5x14 injectors.
After that I ran an H1c with a 12cm HX35 housing, same injectors. Drilled out its divider and hogged it out to 1/8" smaller than the WG flapper, and even that was able to control boost levels. I was never able to get it to creep higher than what I set it at.
Postby 93flatbed » Fri May 23, 2014 8:00 pm
The guy who is helping me reach my goal (very well know puller engine builder) told me the 50mm will be a tad big but if I choose to get crazy later down the road with funny gas or what ever it will allow me to grow.
93flatbed
Postby oldestof11 » Sat May 24, 2014 5:12 am
FWIW, I've only seen up to 44mm gates on daily drivers.
Postby v8coupe » Sat May 24, 2014 12:20 pm
My plans are steedspeed t3 external wastegate, HX35W (from a 24v manual), a synapse 50mm wastegate, 12cm Hx35 non-wg housing and some bigger injectors. Later I have a Billet D12 Hx52 to make my twins with.
v8coupe
Postby 93flatbed » Sat May 24, 2014 6:56 pm
35/52 compounds? It would be super quick spool but not much air I think?
I ran a 52 as a single with a VE and it was able to light it. Don't get me wrong it was a pig low but came on in the 1,800ish rpm range.
93flatbed
Postby Tacoclaw » Sun May 25, 2014 6:19 am
Hx52 is either a 67 or 71mm inducer, depending on which one he has. As far as I'm concerned a 67mm turbo is able to provide more thN enough air to max out a VE's HP numbers. Trick is getting it lit fast enough to do it.
The exhaust housing on the 52's are pretty tight too. May end up being restrictive enough to slow down the 35's spool. If I think right the hx55's turbine housings interchange, so it shouldn't be too hard to open that up some.
Postby v8coupe » Sun May 25, 2014 11:39 pm
Tacoclaw wrote:Hx52 is either a 67 or 71mm inducer, depending on which one he has. As far as I'm concerned a 67mm turbo is able to provide more thN enough air to max out a VE's HP numbers. Trick is getting it lit fast enough to do it.
My HX52 is tge 67mm unit I believe it's a 67/85/16cm will require large wastegate on hot pipe to keep boost from spiking, but I already understand that. Running both turbos at ~2.2 bar will flow enough for 450hp and should have no problem spooling by 1800. Goal is loads of Torque.
v8coupe
Postby DMan1198 » Tue May 27, 2014 5:35 pm
Wow that's a bigger turbine wheel than the s467 fmw I've got coming for my 4th gen. It's a 67.7/83/.9 t4. I'm going to mount it on a t4 steed speed that has the flange straight out (and it just shipped today!!) I didn't get the wastegate flange because I don't need one yet
Postby v8coupe » Tue May 27, 2014 10:16 pm
DMan1198 wrote:Wow that's a bigger turbine wheel than the s467 fmw I've got coming for my 4th gen. It's a 67.7/83/.9 t4. I'm going to mount it on a t4 steed speed that has the flange straight out (and it just shipped today!!) I didn't get the wastegate flange because I don't need one yet
I was off relooked it looks to be a 77mm so a 67/77/16 and is rated to over 1200 cfm and stable to over 60 PSI on it's own. As a compound it won't even be pushed to it's limits and the VE will have trouble fueling it to full power. I'd be happy with 500hp really goal is only to hit 1000wtq.
v8coupe
Postby DMan1198 » Thu May 29, 2014 5:08 am
If you can get it lit fast enough 1000lb-ft of torque should be relatively easy with a ve
