1972 Ford Crew Cab Conversion
Re: 1972 Ford Crew Cab Conversion
Postby dazedandconfused » Thu Apr 10, 2014 3:54 am
Looks good.
Postby grinnergetter » Wed May 28, 2014 6:20 pm
The wife had some back surgery but I finally got to hideout in the red fortress of solitude.
Crew came out of the barn to install bed, throw 300 pounds in the back for fuel simulation and get some leaf measurements to get her leveled out.
Ididit column and wheel:
Check this out! $150.00.....SCORE!!!!!!
No idea what I'll put it in or if it runs but the price was good enough for the girls I go with. :D
grinnergetter
Postby dazedandconfused » Wed May 28, 2014 6:25 pm
What a lucky SOB on that 4B, I'm jealous.
Postby ellis93 » Wed May 28, 2014 6:28 pm
Man I wish I could fall on one too! :lol:
Postby grinnergetter » Thu May 29, 2014 8:03 pm
It was really dumb luck that we even got to talking about diesels. I got from fan to bellhousing less pressure plate and disc . We had to tow a chevy out of the way to get to it and use a comealong to pull the chevy back in the garage but I got it. I told him it would be easier to scrap the chevy. :D
grinnergetter
Postby PapeCAT » Wed Aug 06, 2014 8:35 am
Any updates on this ole' 72.
PapeCAT
Postby grinnergetter » Tue Aug 19, 2014 5:41 am
The goal was to have the chassis boxed, blasted and painted before winter but time is gonna be tight. Sold my P Ranger and got my grandpa's 62 Willys from my dad but sure enough he let it sit too long and now my free jeep has cost me an engine rebuild along with the "might as well replace this while I'm here" stuff. Gotta have a plow vehicle so I have to get it finished up before I get back to the crew.
I should use the guilt of no progress as motivation huh?...LOL
grinnergetter
Postby grinnergetter » Sun Dec 28, 2014 7:54 pm
Bout dern time...The wife ended up having a second back surgery and she still aint right, Ive had to pretend I'm a good husband for way too long.
Got in a load argument with a custom rifle and had to do a full rebuild on the Jeep engine..... I finally had a day to do Ford truck stuff..wooohoooo!!!!!
Faster and more dependable due to the Ford blue engine: LOL
One man cab removal system:
Rear leafs from National Spring:
Heated Mastercrafts:
Pulling the engine to do some frame fixin and reworking stuff I did that kinda sucks:
grinnergetter
Postby grinnergetter » Tue Feb 24, 2015 6:28 pm
Frame is now...FINALLY....fully welded. Next up is x-members.
grinnergetter
Postby grinnergetter » Tue Mar 03, 2015 5:24 pm
I got one of the XM's made today and got the rear axle back in. Need the front axle and engine assembly to start working on a skid plate.
This is probably going to be a landing spot for a torque arm so I'm going to wrap the lower end with some 3/16 or 1/4 to add a bit of strength.
Holes on top are for rear cab mounts and the side pic shows how where I sleeved the frame. I was gonna kill a bunch of drill bits so a small mag drill/cutter set has been ordered. I can sharpen the smaller ones good enough but I had a heck of a time trying to sharpen a 13/16's.
grinnergetter
Postby grinnergetter » Sun Jan 24, 2016 6:39 pm
So...I got "IT" handed to me on this project. While admiring my work when I boxed the frame I noticed the passenger side right where my new X member was placed...well it was kinda crooked. So the truck had been hit at some point. I had to remove the engine mounts and x member. I got her fixed and then I just ran out of motivation and parked it for a while.
So now it's been back in the barn for a while and been pecking at it now and then. Ive had the engine dangling for about 3 weeks now so I gotta get something done.
Decided to make the engine mounts removable.
This allowed me to get more clearance for the TC.
I was also able to move the I/C toward the rear to get it in behind the grill. Which moved the radiator as well. Which means the engine had to move back as well. Which means the engine will be moving back into the cab. Which...god only knows what's next.
Bottom I/C supports.
Mods needed for radiator. Been working on a plan with the guys at Ron Davis. Waiting for CAD and my approval. Will be a dual pass with inlet and outlet on the passenger side and all brackets for shroud and core support attachment points. The driver side will have to be tapered left to right and front to back to clear the steering box....Sheeesh!
Til next time and hopefully it wont take so long for an update. :oops:
grinnergetter
Postby CumminsPower59 » Thu Jan 28, 2016 11:12 am
Looking good. Glad you are able to get back to it and keep working on it ;)
Postby dazedandconfused » Thu Jan 28, 2016 3:49 pm
I get like that on projects too. Glad too see you still pecking away at it.
Postby grinnergetter » Mon Feb 15, 2016 6:42 pm
Made a new trans plate :
Connected to 2.0 DOM...not finished yet.
Self supported....Finally
Ron Davis delivery....hehehehe
Fabbed x member, tacking in tomorrow and then making a skid out of some AR 1/4 plate.
grinnergetter
Postby 93oneton » Wed Feb 17, 2016 8:16 am
Some very nice fab work goin on here! Keep it up!
Shit happens
93oneton
