ellis93 wrote:I haven't heard of anyone running hydraulic fluid in one but I probably wouldn't. These transmissions are piled up with torrington(sp) bearings.....not the thrust washers that the mopar trans are.
I also know that lubrication is critical for those bearings to live so I would tempt fate by running overly thick fluid.
DodgeFreak wrote:ellis93 wrote:I haven't heard of anyone running hydraulic fluid in one but I probably wouldn't. These transmissions are piled up with torrington(sp) bearings.....not the thrust washers that the mopar trans are.
Not sure if they are the same but the mopar OD has torrington bearings in it with people running hyd fluid with no ill effects...(not that I've heard anyways)
ellis93 wrote:DodgeFreak wrote:ellis93 wrote:I haven't heard of anyone running hydraulic fluid in one but I probably wouldn't. These transmissions are piled up with torrington(sp) bearings.....not the thrust washers that the mopar trans are.
True but roughly 3x the size of the gm stuff. They're tiny tot.
