cruise control went out
Postby doc187 » Fri May 09, 2014 2:54 pm
My cruise control stopped working. Any tips on where to start as far as diagnosing the problem? It's a 93 W250 LE
doc187
Re: cruise control went out
Postby CumminsPower59 » Sat May 10, 2014 10:40 am
Did your speedometer stop too? There are several things and connections to check like the brake switch, neutral safety switch, etc.
Postby doc187 » Sat May 10, 2014 11:48 am
No everything else works. It's just the cruise control. The vaccine house to the control unit has been recently replaced and still looks good.
doc187
Postby Ryker Carruthers » Tue May 13, 2014 8:28 am
Could be the buttons or the clock spring as I was told. I think I am going to put mine on a toggle switch. I'd like to make it work as a high idle too to warm the truck up.. Can one do that?
Ryker Carruthers
92 W250 g360 3.55's
Ryker Carruthers
Postby CumminsPower59 » Tue May 13, 2014 10:31 am
There is a write up over on Cummins Forum. You'll have to dig for it. Why not fix the problem correctly instead of cutting into the wiring? Dodge Dakota clocksprings can be made to work along with good used, or new switches can be had. Get a multimeter and check each part before putting parts on it blindly.... it may be something really simple ;)
Postby CumminsPower59 » Tue May 13, 2014 10:33 am
Postby Ryker Carruthers » Tue May 13, 2014 12:03 pm
Thanks Ike!
Ryker Carruthers
92 W250 g360 3.55's
Ryker Carruthers
Postby doc187 » Tue May 13, 2014 1:59 pm
I'd like to fix it correctly. I've got a multimeter but am not sure how to test the clock spring or the buttons. Any advice would be greatly appreciated.
doc187
Postby CumminsPower59 » Tue May 13, 2014 2:39 pm
Might have to dig up a wiring schematic so you can check continuity between points/pins...meaning that there isn't a break in the circuit...
Postby doc187 » Sat May 17, 2014 12:01 am
I used the service manual and a volt meter meter to troubleshoot it and it's the switch. Does anyone know where I can find one?
doc187
Postby Fred_M1010 » Fri Jun 13, 2014 12:51 am
The clock spring on mine is broken.
Does anyone know where to get a new one?
Or know a part number so I can search?
Sorry for the hi-jack :oops:
-91.5 W250
Fred_M1010
Postby CumminsPower59 » Mon Jun 16, 2014 10:08 am
Cheapest option, new aftermarket Dakota unit and modify the plugs to work with ours. They aren't as spendy as the replacements from the dealership, if they are even available anymore. I paid $200 for one in 2004...
Return to Electrical
