Will a Bilstein work? -Steering Stabilizer/Dampener
Postby McGee7 » Sun Jun 29, 2014 12:43 pm
I have a 1991 w250 that needs a new steering stabilizer. I see that Bilstein doesnt make them for older trucks, so does anybody know if they have any that would work for my truck anyways? Would the Bilstein 5100 series work?
McGee7
Re: Will a Bilstein work? -Steering Stabilizer/Dampener
Postby RCCUMMINS89 » Sun Jun 29, 2014 10:19 pm
Will a 5100 shock work as a stabilizer? No, Bilsteins push up all the time as opposed to keeping things where they are.
Postby BILTIT » Sun Jun 29, 2014 11:53 pm
I went with bds for my dual steering stabilizer setup, wasn't cheap though.
Derek B.
BILTIT
Postby DodgeFreak » Mon Jun 30, 2014 9:55 am
RCCUMMINS89 wrote:Will a 5100 shock work as a stabilizer? No, Bilsteins push up all the time as opposed to keeping things where they are.
I know a kid that done that once.......always wanted to make a right hand turn :lol:
Postby McGee7 » Mon Jun 30, 2014 8:25 pm
McGee7
Postby RCCUMMINS89 » Mon Jun 30, 2014 8:39 pm
Yes. Thank you for posting that, I never knew they made one.
Postby McGee7 » Mon Jun 30, 2014 8:48 pm
Yeah I just didn't know if it would work for my year truck.
McGee7
Postby RCCUMMINS89 » Mon Jun 30, 2014 9:07 pm
What do you plan on using for brackets?
Postby McGee7 » Mon Jun 30, 2014 9:09 pm
It has some already on it- i'm just replacing the stabilizer itself.
McGee7
Postby RCCUMMINS89 » Mon Jun 30, 2014 9:27 pm
No idea... BILTIT will hopefully chime in and let us know where he found the specs on the Bilstein stuff. That way we can look the thing up and see.
Postby BILTIT » Tue Jul 01, 2014 8:00 am
I didn't think they made a steering stabilizer. When i ordered my shocks the distributor said they didn't make one so either the stabilizer is new or the distributor lied to me.
Either way if you go to the link provided above and click on the "dowloads" icon it brings up part numbers for different trucks.
They don't show a stabilizer for anything older than a 3rd gen dodge. They don't show one for a K3500 or old ford (all had the same front axles).
Kinda SOL i think without having a some in your hands to measure up, might be worth a phone call to someone in Bilstein.
Derek B.
BILTIT
Postby RCCUMMINS89 » Tue Jul 01, 2014 12:40 pm
Biltit... do you have the p/n for those BDS stabilizers... just the stabilizers.
Postby BILTIT » Tue Jul 01, 2014 5:18 pm
BDS stabilizers are BDS55422, for a 09+ dodge ram.
Derek B.
BILTIT
Postby ccab85 » Wed Jul 02, 2014 3:51 pm
Steering stabilizers use the same pressure on compression and rebound whereas a shock uses different rates for rebound and compression. I just use monroe stabilizers. There should be a part number stamped on your old body if you still have it, most numbers can easily be cross refenced.
91.5 W350 345k stock
ccab85
Postby McGee7 » Sun Jul 06, 2014 2:35 pm
Has anybody used a Bilstien steering stabilizer on a Dana 60?
McGee7
